Left Tail Light Out Completely- Fuse and Bulbs Okay - JeepForum.com
post #1 of 6 Old 05-15-2013, 09:49 PM Thread Starter
Lindsaydt86
Hello! I am having a hard time figuring out what is wrong with my tail light in my 2010 Jeep Wrangler. All of the left lights went out at the same time (turn signal, reverse, brake, and parking). I have replaced the bulbs and the fuses but it is still no power to the entire light. Any suggestions?
Lindsaydt86 is offline
post #2 of 6 Old 05-16-2013, 07:23 AM
giggityjeeper
Sounds like a wire is cut somewhere grab a test light and trace it back
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #3 of 6 Old 05-17-2013, 06:25 AM
festerw
festerw's Avatar
Honestly go to the dealer, their scan tool will be able to pinpoint the issue faster than you chasing wires. The TIPM while a horrendous pain in the butt is actually fairly accurate in that area...assuming of course the TIPM itself isn't the issue.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #4 of 6 Old 05-17-2013, 06:26 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Do the JKs ground through the housing like TJs? It is a ground as that is only thing they all have in common.
RnEmOvr is offline
post #5 of 6 Old 05-17-2013, 06:27 AM
RnEmOvr
RnEmOvr's Avatar
I could install LEDs for less than they would charge to find the problem.
RnEmOvr is offline
post #6 of 6 Old 05-17-2013, 06:32 AM
festerw
festerw's Avatar
I'm lucky that the dealer near me is actually fairly reasonable for diagnostics. It was under $200 to get the diagnostic and 3 wires repaired in the brake circuit on my old Patriot.
festerw is offline
bulb , fuse , tail light
