keep the 37's or go bigger?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > keep the 37's or go bigger??
Ruffstuff 10 year saleSave up to 10% on Rugged Ridge - ExtremeTerrain!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-20-2010, 09:12 PM   #1
highrolrcustoms
well i have about 250 miles on my 37x13.50's now and i just added the new mc enterprises front fenders and have tube fenders on the way....should i keep the 37's or go to a bigger tire to fill the opening...if so what size???
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
[url]http://www.jeepforum.com/forum/f12/3-4-ton-axle-swap-has-begun-1108933/[/url]
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline   Reply With Quote Quick reply to this message
Unread 08-20-2010, 09:38 PM   #2
Gint2
Plain and simple... You need a bigger tire or smaller lift.
J.M.H.A.O.
Gint2 is offline   Reply With Quote Quick reply to this message
Unread 08-20-2010, 09:52 PM   #3
Imped
Imped's Avatar
Lower it down ~5", lengthen shock mounts, stick with 37's. If you still have the D30 up front, you're already on the line.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 08-20-2010, 09:57 PM   #4
highrolrcustoms
1 tons are in the works along with stretched wheelbase......im not wanting a daily driver....
Unread 08-21-2010, 12:20 AM   #5
Imped
Imped's Avatar
Where did I mention anything about it being a DD?
OlllllllO
Float Test Build
IndyORV
Unread 08-21-2010, 12:23 AM   #6
R0cket
1930 TJ Wrangler
i think he was just telling you in-case you became overcome with curiosity...
Ian
AME2 USN, Disabled Vet
R0cket is offline   Reply With Quote Quick reply to this message
Unread 08-21-2010, 12:25 AM   #7
R0cket
1930 TJ Wrangler
in that case, i say go up to 40's and drop down to about 2.5" lift.
Ian
Unread 08-21-2010, 12:41 AM   #8
1997_Sport
he has a 2.5" lift....just modified a little.
Go with 40s or 42s if you are getting tons.
1997_Sport is offline   Reply With Quote Quick reply to this message
Unread 08-21-2010, 04:01 AM   #9
highrolrcustoms
sorry about the daily driver deal....just giving you all a heads up....its gona be a trailer queen to the trails......i was thinkin 40's but not sure..... yes i have 2.5" lift on top of a 7.5" rock road spring over conversion and 2" body lift....total of 12" lift lol
Unread 08-21-2010, 04:06 AM   #10
WhiteOut
WhiteOut's Avatar
44's
WhiteOut is online now   Reply With Quote Quick reply to this message
Unread 08-21-2010, 11:52 AM   #11
-ExDementia-
1991 XJ Cherokee
I say stock springs on the SOA with 40's
BTW whats your rear axle right now?
"The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to get the job done.'" [B]- George Carlin[/B]
[B][SIZE="3"]Click [URL="http://www.jeepforum.com/forum/search.php"]HERE[/URL] for the elusive search button everyone talks about.[/SIZE][/B]
-ExDementia- is offline   Reply With Quote Quick reply to this message
Unread 08-21-2010, 11:56 AM   #12
1997_Sport
I say keep the height because its sexy, and once you get the tons for 40s.
Unread 08-21-2010, 12:26 PM   #13
WILLY348
I do believe the axle gear ratio limit for your Dana 30 is 4.88.. not nearly low enough for any thing larger then 37's. You'd also want to upgrade the axles for bigger tires.. you should already want bigger axles for those 37's!
2003 Jeep Wrangler Sport: Current Jeep
2006 Jeep Wrangler Unlimited: (Sold and missed!)
2004 Ford Mustang Cobra http://s249.beta.photobucket.com/use...89_o1.jpg.html
WILLY348 is offline   Reply With Quote Quick reply to this message
Unread 08-21-2010, 12:34 PM   #14
1997_Sport
I guess you dont know how to read do you?
Unread 08-21-2010, 01:06 PM   #15
jerseyjeep22
yeah he's getting one tons, but how far away is that? I wouldnt want to ride around with 40's on a dana 30/35(probably what he has currently lol) for more than 15 minutes, let alone 2 months or however long hes gonna wait
jerseyjeep22 is offline   Reply With Quote Quick reply to this message
