keep the 37's or go bigger?? - Page 2 - JeepForum.com
post #16 of 20 Old 08-21-2010, 12:22 PM Thread Starter
highrolrcustoms
yeah im really gona break those stock axles with it sitting in the driveway and not being driven......the d60 and 14 bolt are a winter project...im trying to get all the parts to do everything at once....and ill be nice and leave it at that
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #17 of 20 Old 08-21-2010, 12:23 PM
Jake03TJ
1 tons axles and 40" MT/R's IMHO...
ΜΟΛΩΝ ΛΑΒΕ
Jake03TJ is offline
post #18 of 20 Old 08-21-2010, 12:28 PM
OneLoud
You really need to put much bigger tires on there...and then sell me your 37's!
OneLoud is offline
post #19 of 20 Old 08-21-2010, 12:44 PM Thread Starter
highrolrcustoms
if i go bigger which i am pretty sure i am...ill deff be looking to sell the tires and maybe wheels... also should i stick with a 13.50 like im running or go wider with a 14.50 or 15.50
post #20 of 20 Old 08-21-2010, 01:00 PM
OneLoud
WIDER! Anything over 37" should be at least 14" wide!
OneLoud is offline
Bigger tires, bigger problem. CopMech YJ Wrangler Technical Forum 5 04-20-2010 06:21 AM
bigger tires bigger brakes? APEDZ04LJ TJ Wrangler Technical Forum 7 10-25-2009 05:57 PM
Bigger Lift means Bigger Problems?? Jeep Kid TJ Wrangler Technical Forum 1 03-08-2008 03:41 PM
is anyone running 37's or bigger on dana 44s codymparmy TJ Wrangler Technical Forum 11 07-07-2007 08:04 PM
Bigger wheels, Bigger problems??? mudstuck TJ Wrangler Technical Forum 9 09-28-2003 10:03 PM
