jeep wont start but battery is good - JeepForum.com
post #1 of 5 Old 08-12-2010, 11:07 PM Thread Starter
Utfan010
so i drove my jeep to my friends house today turned it off went inside for about 15 minutes then came back out to my jeep not starting up at all. all the lights on the dashboard were faded the radio wouldn't turn on, the light under the hood was barely glowing, and finally went out. we then jumped it. and i drove it home right when i got home the battery meter was pinned all the way to the right i turned it off it wouldn't start back up, so i then took the battery to advance auto parts and they said my battery was good with 12.7 reading. i then had a friend come by from the dealership and he's checking out my alternator tomorrow morning. any other ides of what it could be?
please help cause i need my jeep back.
when in doubt, press the skinny pedal!
Utfan010 is offline
post #2 of 5 Old 08-12-2010, 11:10 PM
Bane7962
Check your connections?
Corrosion, gunk etc?
Working with cars is a little like a really awesome date: you start out expecting this to be something simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought.
When my Jeep stops making strange noises, I become concerned. That usually means I have to go back and find whatever fell off.
Bane7962 is offline
post #3 of 5 Old 08-13-2010, 10:13 AM
DanZ51
If you mean the dash volt meter was pinned .
Did they load test the battery at Advanced Auto, or just check voltge? Sounds like you got corrosion crawling up your battery cables, start looking. Also check the altenator for correct voltage and test if a diode plate burned out (AC voltage present).
"I will always be an American Soldier"
DanZ51 is offline
post #4 of 5 Old 08-13-2010, 09:54 PM
fishinjeeper
Ya, did they do a load test? that would say if they are just reading a surface charge or actual charge
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #5 of 5 Old 08-13-2010, 11:02 PM Thread Starter
Utfan010
haha yeah i meant the volt meter...haha
but the battery was indeed good. i took the alternator up to advance auto parts and had them test it, it was the problem. they said it was defective from not putting out enough volts, but i went to car quest got a rebuilt one with a 1 year warranty and my jeep is now running so much better and smoother
Utfan010 is offline
alternator , battery , jeep , volt meter , wrangler
Help Please. TJ wont start after new battery and alternator smithins TJ Wrangler Technical Forum 8 08-14-2010 01:41 PM
95 yj wont start but its not the battery sweetsundog4 YJ Wrangler Technical Forum 20 05-13-2010 01:16 PM
Bought a new battery and jeep still wont start footman TJ Wrangler Technical Forum 10 02-19-2009 10:16 PM
Please help!!! Jeep won't start but battery and starter are good usmcwrangler YJ Wrangler Technical Forum 10 09-14-2008 06:58 PM
Jeep wont start, then died after being jumped....battery? alternator? JJs99TJ TJ Wrangler Technical Forum 71 08-04-2006 08:04 AM
