installing winch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > installing winch
Engo winches available at www.rockridge4wd.com! Free shippThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff 3 Link Kit!
Unread 07-15-2014, 04:20 AM   #1
mikefreedy
installing winch
So I purchased a winch for my ****tybilt xrc tj bumper and the frame is so far under it I can't get a ratchet in there to send the bolts up. And ideas?
mikefreedy is offline   Reply With Quote
Unread 07-15-2014, 08:18 AM   #2
biffgnar
biffgnar's Avatar
Remove bumper from jeep. Mount winch on bumper. Remount combined bumper/winch.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 07-15-2014, 08:36 AM   #3
mikefreedy
The bumper took almost 4 hours to install. It's not coming off. Any other thoughts
Unread 07-15-2014, 09:06 AM   #4
biffgnar
biffgnar's Avatar
Let's put it this way. Think about the forces on that winch and it's mounts when you are doing a hard pull. Making sure the mounts are strong enough and secure is a big safety issue. Doing something half assed because you don't want to spend the time is a bad idea.
I know nothing about that bumper, but 4 hours seems crazy by the way. Most bumpers I've seen would be maybe 30 minutes tops, in particular any time after the initial install (when your figuring it out and dealing with any unforseen snags).
Unread 07-15-2014, 09:22 AM   #5
mikefreedy
We had to heat and bend wrenches because of the little space that they leave you can't fit a ratchet anywhere
Unread 07-15-2014, 09:28 AM   #6
biffgnar
biffgnar's Avatar
Sounds like you needed a stubby open end or a crow foot wrench. A few bucks on the right tools can make all the difference in a job.
Unread 07-15-2014, 09:28 AM   #7
frenchy206
You need to get new tools. When I installed my bumper, it took less than a half hour. It does get tight in there. That's why God made these.
03 TJ Rubicon
frenchy206 is offline   Reply With Quote
Unread 07-15-2014, 09:32 AM   #8
222Doc
two way tape, some JB weld, a few zip ties and duct tape should hold it..
[URL=http://www.bullhead4wheelersinc.com[/URL]
222Doc is offline   Reply With Quote
Unread 07-15-2014, 09:37 AM   #9
2jhanna
OP, if you had started the bumper removal when you started this thread you be through by now with the wench installed.
jhanna
denton county, tx
2jhanna is online now   Reply With Quote
Unread 07-15-2014, 09:42 AM   #10
mikefreedy
Cool thanks ill go snag one of those
Unread 07-15-2014, 11:03 AM   #11
bogleparsons
That's why I hate recessed winch mounts.
I want my winch on top of the damn bumper so if I have a problem I can diagnose it easily.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is online now   Reply With Quote
Unread 07-15-2014, 11:42 AM   #12
mikefreedy
I agree
Unread 07-15-2014, 12:35 PM   #13
frenchy206
The nice part of a recessed winch mount is that 1, you get less blockage of air to your radiator and 2, lowers the center of gravity.
03 TJ Rubicon
Unread 07-15-2014, 08:06 PM   #14
Demp
3. can deter casual theft as well
I'd consider specialized wrenches as previously mentioned.
I have the AEV bumper I installed myself, before the winch. The AEV stuff can be a bit more complex to get on, especially since the instructions are sketchy. Once you've installed something once, removal and reinstall is a LOT faster.
3-4 hours to get it on the first time, since it has some assembly required.
4 total hours to remove it again, drill/cut pump bracket to fit the winch plate, mount winch, remount bumper.
Demp is offline   Reply With Quote
