Improving MPG... - JeepForum.com
post #1 of 22 Old 09-09-2012, 12:53 PM Thread Starter
Jachi101
Improving MPG...
http://greensource.ca/
Does anyone have experience with any of these. Do they actually work?
Jachi101 is offline
post #2 of 22 Old 09-10-2012, 04:26 AM
roadyrob
1987 YJ Wrangler
no, they don't produce enough Hydrogen to make a difference.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 22 Old 09-10-2012, 09:06 AM
Xpress
How to improve Jeep Wrangler MPG:
1. Don't drive it.
2. Take the Camry instead.
All about that unibody life.
Xpress is offline
post #4 of 22 Old 09-10-2012, 09:56 AM
robplumm
1. Don't drive it.
3. Sell it.
robplumm is offline
post #5 of 22 Old 09-10-2012, 06:01 PM
eastcoastcam
If this works like they claim, it would not be so affordable. Look on the "products page"... in the first few pics, they have PowerFist rocker switches and fuse holder.
eastcoastcam is offline
post #6 of 22 Old 09-10-2012, 06:13 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
Originally Posted by robplumm View Post
3. Sell it.
Gosh no! Get a second job for that $3.99/gal. gas.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #7 of 22 Old 09-10-2012, 06:31 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by Jachi101 View Post
Jerry Bransford is offline
post #8 of 22 Old 09-11-2012, 09:23 AM Thread Starter
Jachi101
Alrighty then, ill take that as a no. Thanks for the input everyone
Jachi101 is offline
post #9 of 22 Old 09-11-2012, 04:15 PM
Zombi
Nothing has made more of an impact on my mileage than switching to 4-port fuel injectors.
I've increased mileage 20-30%.
That being said, the crap that came out of the fuel rail when I cleaned it and the old fouled out injectors may be why I was getting such bad mileage in the first place. YMMV
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #10 of 22 Old 09-11-2012, 04:36 PM
terpsmandan
2009 JK Wrangler
i have found one solution. CEL came on 2098 lean mix. Don't know if it's a manifold leak or an O2 sensor but my MPG has gone up from 16 to 18.
terpsmandan is offline
post #11 of 22 Old 09-11-2012, 04:37 PM
Fellstar
Don't know if you're joking or not but running lean is pretty much the worst thing you can do to a gas engine.
2012 Rubicon - ACE Eng. Rock Sliders, Rockhard4x4 Full Front Bumper, SmittyBilt XRC8, Level 8 Strike 5 16x8.5's wrapped in 315/75-16 Nitto Terra Grapplers, 3" Teraflex coil lift with shock adapters, Teraflex HD Tire Carrier Hinge, Teraflex Exhaust Spacers. 1/2" coil spacer up front, 3/4" coil spacer in the rear.
Fellstar is offline
post #12 of 22 Old 09-11-2012, 08:07 PM
Xpress
And you'll be out an engine pretty damn quickly if it's running lean. There goes your MPG.
Xpress is offline
post #13 of 22 Old 09-12-2012, 08:13 AM
Bigshankhank
Huh, I had heard about that from a Jeep shop I used to take mine to back in Clearwater but never seriosuly considered it. How difficult was that change? Simple matter of pulling the rail and replacing the injectors, or did you have to remap or otherwise jigger with the electronics?
Bigshankhank is offline
post #14 of 22 Old 09-12-2012, 09:20 AM
mdm
Farm Wheeler
Our engines run leaner than ideal already to help meet emissions standards. Running even leaner should really be good on the valves and pistons.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #15 of 22 Old 09-12-2012, 10:41 AM
Zombi
100% bolt in swap.
Pull the electrical plugs off the injectors, pull the rail and the injectors just pull out.
The whole thing took me maybe an hour and a half and most of that time was spend cleaning the fuel rail and injector ports.
The set I have is flow matched so all injectors flow at the same rate and put out the same amount of fuel as the factory injectors. They just get it done more efficiently.
No computer reprogramming is required.
With the increased mileage I got from this swap, the injectors will pay for themselves within 6 months, then start paying me in the form of saved fuel.
I always want to give an honest review of these, 1 of my old injectors was fouled out and leaking, 2 more were suspect. I can't claim that these injectors are 100% responsible for the mileage increase because my baseline was so messed up. That increase may have happened because they are functioning correctly now and the rail is clean.
BUT, if I were in the same boat again looking to replace injectors, I would go this route without hesitation.
Call me Z
Zombi is offline
mpg
Improving Gas Mileage in 4.0 cujo3969 YJ Wrangler Technical Forum 34 03-30-2016 09:23 PM
Improving MPG..... GilNewJeeper YJ Wrangler Technical Forum 17 09-17-2010 03:58 PM
Need help. (Improving MPG on 4 cyl) Rocky_Romper TJ Wrangler Technical Forum 1 12-02-2009 05:51 PM
Improving HP & Torque - HOW? IMYY4U JK Wrangler Technical Forum 18 04-14-2008 01:46 PM
Improving MPG steveo132 TJ Wrangler Technical Forum 38 09-09-2007 05:39 PM
