I need a distributor drive assembly - Page 2 - JeepForum.com
post #16 of 23 Old 08-30-2010, 12:15 PM Thread Starter
EUGENE1
So Chrysler must have enough loyal customers that they don't need me to be Loyal to them any longer. They have now decided that they will only pay half of the repair no matter how extensive the repair costs are. But I have to allow the dealer to do a tear down on the engine to diagnose the problem internally which I have to pay. Then they will decide how much of the repair they will pay for. You'd think that with them already having this issue on so many Jeeps (250 were on B/O at least) that they would just admit that they made a mistake and pay for this especially 5000 miles out of warranty. The '05's & 06's were right in line with each other at build time. You know the didn't take away all of the left over parts when the 05 production stopped & 06 production started. My 06 went right down the line getting the DEFECTIVE DRIVE GEAR that has now failed & cause $$$$ in damage to my engine. I guess the fact that I have been a loyal Jeep customer for more than 10 years and have personally owned at least 6 Jeeps in the past 10 years means nothing to them.I guess also the fact that I have my own part-time jeep business dealing with XJ Cherokees where I buy & sell to keep the product out there means nothing to them also. It sure wouldn't be that hard to start buying Japanese vehicles from now on. I could even start my own Japanese car part-time business.
The LOYALTY STOPS HERE......I figured something out today. Toyota builds a nice off road vehicle called "FJ" I think it means "F*@# JEEP!" I LIKE IT!
Any body want to buy a nice Jeep? Needs minor Engine repair.....
EUGENE1 is offline
post #17 of 23 Old 02-02-2011, 04:01 PM
nate2630
Help!
I have had my 05 in the shop for 5 weeks now and they pushed back release date to 4-18-11? If anyone has an extra or knows where to get one I would pay them an extra hundred or more!
Please help!
Nate 970-390-9591
nate2630 is offline
post #18 of 23 Old 02-02-2011, 04:53 PM
Unlimitedlou
What is wrong with yours? If it is making noise, figure out what the problem is. Is it the gear, lower bushing, or upper bushing? I could not get one for several months, so I took mine apart and found the top bushing was wore badly. I took it to an autmotive machine shop and had them install an Oillite bushing. I ran it for a few months until I could get a new one. Good luck.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #19 of 23 Old 02-02-2011, 07:03 PM
willydigger
Here is the new failure thread.
http://www.jeepforum.com/forum/f9/20...ilure-1144202/
For those of you with bad OPDA's, like the above poster said what is the problem? Squeals, codes, engine performance? There are options. This is a big deal, but if you can catch it before you blow up your engine there are ways to get through it.
willydigger is offline
post #20 of 23 Old 02-02-2011, 07:12 PM
willydigger
What dealer? I'm in Baltimore too. Heritage Jeep on Harford Rd. tried to get me for $490 for the OPDA replacement. They eventually covered it under warranty for $100 deductible. Is the engine shot? What were the details of the gear breaking?
post #21 of 23 Old 02-03-2011, 09:32 AM
nate2630
I found the repair kit and it should be here tomorrow! I hope it works. Mine was bad and damaged the cams could not go over 2500 rpm.
nate2630 is offline
post #22 of 23 Old 02-03-2011, 06:23 PM
willydigger
I don't doubt what you're saying, but cam damage is probable but not necessarily a cause for not being able to get about 2500rpm. If the OPDA was put in wrong so that the pulse does not match in the computer, the computer will limit the rpms to protect the motor. For example I could go outside and turn my OPDA so it isn't aligned correctly and my rpms will not go above 2500. I can then turn it back and it will be fine.
When you say it was bad, who looked at it? What did it do when it went bad?
Did the gear break?
How many miles were on the Jeep?
Even when you put a new OPDA in, if the cam is bad, the motor will not run correctly if at all. Please have a look at the OPDA failure thread. It may help you understand how it works and it might help you tell us what is wrong.
Lastly, when you replace the OPDA, it will likely fail again. The upper bushing is not properly lubed and will heat up and bind the shaft. There is not difference in the one that came installed back in 2005 and the ones that are on back order now in 2011.
If anyone is reading this go to the above link. It's got a ton of pics as well as a thorough explanation of the problems and home brew solution. If you have a question let us know. This problem can be fixed if caught early enough.
post #23 of 23 Old 02-04-2011, 12:21 AM
nate2630
They said it was worn excessivly and they are replacing under warranty.
nate2630 is offline
Distributor , drive assembly , lj , wrangler
Oil Pump Drive Assy / Distributor / Cam Synchronizer Unlimitedlou TJ Wrangler Technical Forum 13 01-22-2011 09:00 PM
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
Safe to drive with one 13mm bolt from hud assembly broken? BWFBezerk TJ Wrangler Technical Forum 5 04-21-2009 11:16 AM
Distributor Drive Gear goatboy YJ Wrangler Technical Forum 3 02-15-2007 07:55 PM
