I LOVE my ****** jeep - JeepForum.com
post #1 of 6 Old 12-28-2011, 01:28 PM Thread Starter
beefcake3
in the process of rebuilding my 2.5l 4cl engine to replace the piston rings due to lack of compression iv figured out the problem is that my engine block has been bored before by a previous owner and has oversize pistons but the god damn retard didnt put larger rings on so now at 130k on the engine and having to be re bored because the small rings chewed groves into the cylinders. iv had the damn thing for about 6 months and have only driven it about two weeks of that time the only reason i just dont light the ****er on fire is because other then the engine everythings been replaced by a previous owner its basically a brand new 98 TJ.
QUESTION:
can my block be re bored or will i need a new one????
CYLINDERS:
http://www.jeepforum.com/forum/f176/...-help-1305626/
PISTONS:
http://www.jeepforum.com/forum/f176/...ation-1305969/
beefcake3 is offline
post #2 of 6 Old 12-28-2011, 01:42 PM
roadyrob
1987 YJ Wrangler
your pistons are .030 over, you can bore up to .060. should be able to rebore if the groves aren't to deep. the shop you take it to will know
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 6 Old 12-29-2011, 02:25 PM
Siva283
There is a guy on here that went to .120 over and used flat head chevy pistons and it worked fine. As far as I know he still has it. It is actually a 2.8 now I think. He gained like 25 horse power or something too.
Siva283 is offline
post #4 of 6 Old 12-30-2011, 02:18 AM
Prot
Prot's Avatar
2014 JK Wrangler
Maybe consider an engine swap to 4.0L
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #5 of 6 Old 12-30-2011, 04:42 AM
Siva283
It seems to me that the OP does not want to go to the trouble and headaches of an engine swap. Some of us are fine with our 4 cylinders. Other than picking up speed a little slower and towing more weight our 4 cylinders can do anything the 6's can.
Siva283 is offline
post #6 of 6 Old 12-30-2011, 05:36 AM
Prot
Prot's Avatar
2014 JK Wrangler
It was just a suggestion that opens up possibilities.
I used to know a guy with a four cylinder that had tires too big for the power and I suppose gearing. His Jeep had a top speed of 40 mph as a result.
The possibility of salvaging the engine will largely depend on how bad the damage is and the cost of the repair. Has the crankshaft sustained any damage from the metal shavings or anything?
Prot is offline
How much I love my Jeep...until dellime YJ Wrangler Technical Forum 20 06-28-2011 02:23 PM
Why I love my Jeep Wrangler19 Wrangler General Discussion 48 07-10-2010 05:09 PM
Why you love your Jeep. 2006_Sport Wrangler General Discussion 48 08-26-2009 10:26 AM
why i love my jeep shaun72079 Wrangler General Discussion 6 08-02-2009 10:59 PM
Love the Jeep thejeepest JK Wrangler Technical Forum 15 07-23-2009 09:54 AM
