I just got a jeep... what is this modification? - JeepForum.com
Closed Thread
post #1 of 119 Old 12-22-2011, 12:07 PM Thread Starter
monsteryjSS
I just got this 1993 jeep wrangler yj and inside it has these three switches saying:
front air locker, ARB compressor, and rear air locker. And inside there is this huge compressor with this other thing next to it...
can you guys tell me what that is, why is it good, what its used for, and how much of a benefit i have from this mod?
i'm a total noob to jeeps and this is my first real jeep haha
monsteryjSS is offline
post #2 of 119 Old 12-22-2011, 12:11 PM
Xpress
You have ARB air lockers in your axles. A locker will lock the axle shafts together so that they cannot spin independently of each other. Comes in real handy when you have one wheel in the air, which can happen from time to time. Instead of that airborne wheel just spinning and you losing all traction, a locker will keep that wheel locked to the other wheel that is on the ground, so both wheels drive you forward.
Same exact thing as an ATV rear axle, both wheels spin at the same speed. In an open differential, each wheel spins independently of each other so that there is no binding when going around corners. The air compressor is what powers the lockers, since they are both air powered. In order to activate the lockers you need the air compressor to be on.
Also, you should never lock your axles on the street, or any hard surface where the wheels cannot slip. You can break an axle like that in a heartbeat.
All about that unibody life.
Xpress is offline
post #3 of 119 Old 12-22-2011, 12:14 PM Thread Starter
monsteryjSS
and how much would this set up cost to get it in this jeep? i'm just curious how much money the previous owner spent on this haha.. and i'm pretty sure there are lots of other things i am not aware of that is modified to this jeep
post #4 of 119 Old 12-22-2011, 12:20 PM
Muddy4DSM
Best bet might be to post some pictures, people could have some answers for ya in no time.
OO|||||||OO
Muddy4DSM is online now
post #5 of 119 Old 12-22-2011, 12:26 PM
biffgnar
biffgnar's Avatar
Parts are something like $800 an axle and then installation is similar to gear install which is maybe $600 an axle.
Romney in 2020!
biffgnar is online now
post #6 of 119 Old 12-22-2011, 12:30 PM Thread Starter
monsteryjSS
so there are two axles so parts will be 1600 and installation will be 1200?
post #7 of 119 Old 12-22-2011, 12:31 PM
Moto4x4
Plus the compressor which is another 300ish
Moto4x4 is offline
post #8 of 119 Old 12-22-2011, 12:32 PM
oldtime_ironman
Couple thousand $$$. Somebody spent some real money on this jeep in the past, and its likely they knew what they were doing since it has ARB's.
oldtime_ironman is offline
post #9 of 119 Old 12-22-2011, 12:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Definitely post some pics. I'm nervous to see which axles he chose to install these into.
Luck Favours The Prepared
Anticanman is offline
post #10 of 119 Old 12-22-2011, 01:02 PM Thread Starter
monsteryjSS
yeah and it has lift (I dont know how big but its pretty big) and it has 33 inch tires with offroad tires... i'm pretty sure a lot of stuff is done to this that I dont know about.
post #11 of 119 Old 12-22-2011, 01:31 PM
oldtime_ironman
Well, with 33" tires its probably a 4-inch lift. Pretty decent. Like Anti said, post up some pics sometime, especially the axles front and rear. It'll tell us a lot.
Oh and welcome to the club! You just found one of the best jeep sites anywhere! Be sure to check out the YJ technical forum.
post #12 of 119 Old 12-22-2011, 01:32 PM
rockchamp
You don't need any more switches in the cab....that stuff will only alow you to go farther into the bush to get stuck......what I will do ,,,since I'm in the Christmass siprit, is to take those switches ,air pump axles and all related equipment for said axles off your hands,,,and I will send you my trustly factory reliable dana 30 and dana35 axles that would be better suited for your driving needs......having said that,,,ofcourse you will have to pay all shipping both ways and include a Partridge in a pear tree........
rockchamp is offline
post #13 of 119 Old 12-22-2011, 01:33 PM Thread Starter
monsteryjSS
here are some big pictures.. hopefully with these pictures you can tell me what I bought haha .. oh and thats all mud under the jeep, no rust
post #14 of 119 Old 12-22-2011, 01:35 PM Thread Starter
monsteryjSS
here's the jeep guys.. tell me what you think.. and also, how much do you think this jeep is worth based on these modifications and these: it's a 5 speed, 4.0 high output engine, 160k miles, clean title, and runs good.
post #15 of 119 Old 12-22-2011, 01:38 PM
oldtime_ironman
Excellent! Looks like you have the D44 rear axle, which is very good - heavy duty. Stock front axle. Very clean install, looks like a pro did it. I wonder if it has a SYE (slip yoke eliminator)? Can you post a pic of the rear of the transfer case/transmission? Right where the rear drive shaft comes out.
Beautiful jeep tho, its really clean and looks like it was professionally built! I wish they were that clean up north here, but most of them are gone now due to rust.
Closed Thread
My first modification to my JK damunoz32 JK Wrangler Technical Forum 6 08-09-2009 04:10 PM
Jeep gas tank modification bearhunter YJ Wrangler Technical Forum 8 08-13-2008 04:37 PM
Jeep Unlimited Modification Questions nedyahr TJ Wrangler Technical Forum 4 06-27-2005 11:34 AM
