I have a question on check engine light - JeepForum.com
post #1 of 3 Old 09-01-2010, 06:05 PM Thread Starter
dabunnie
2006 JK Wrangler
Hello
We received a check engine light. I found the code P0133. We changed all four 02 senors but the check engine light still is on. I so need to get that light off because I have to smog it and the Jeep Dealership said the smog folks will not pass it if that light it on. How do I get that light off?
dabunnie is offline
post #2 of 3 Old 09-01-2010, 07:46 PM
fishinjeeper
IT sould reset after sometime. Other then that any mechanic can do it real quick
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #3 of 3 Old 09-01-2010, 07:53 PM
SlackJawedYokel
Disconnect the battery for about 30 minutes, or take it to Autozone or similar. They usually will hook up an OBDII sensor to pull the codes and get the light to turn off for no charge.
How many miles on the Jeep, is it still maybe under warranty?
Youth is wasted on the young.
SlackJawedYokel is offline
check engine light question 92renegade YJ Wrangler Technical Forum 17 01-15-2010 07:38 PM
Check engine light question agent_J TJ Wrangler Technical Forum 2 08-17-2008 05:43 PM
Question - Check engine light odie6423 TJ Wrangler Technical Forum 3 04-16-2007 05:10 PM
check engine light question? REDPILL TJ Wrangler Technical Forum 3 10-12-2006 11:32 AM
check engine light question romiin YJ Wrangler Technical Forum 3 10-01-2006 09:09 AM
