Quantcast How much did your on boad air cost? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > How much did your on boad air cost?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-27-2009, 10:07 PM   #1
wzrroc
I am looking to do an on board air system on my YJ. I have a 2.5L and I plan on using the A/C compressor. I haven't decided if I am going to run a tank or not.
Anyone else running a similar set up? If so about how much did you spend on it?
Thanks.
Green 95 YJ. 2.5L Low output. 2.5" RE lift. 1.25" shackles. 33" BFG Mud Terrains.Build Thread (SOLD)
Jeep #2: Green '98 TJ 4.0L|AA SYE, Tom Woods shaft|4.88s|3" teraflex lift|2" BB|1.25" BL|1" MML|35" BFG All Terrains|Warn XD9000i| Build Thread
Daily Driver: 1991 Ford Escort, white w/ graffitti stencils
"I will never understand why people will spend money on huge rims with skinny tires when you can get small rims (15") with huge tires."
"I'm teaching my jeep to roll over, so keep your distance."
wzrroc is offline   Reply With Quote
Old 11-27-2009, 10:16 PM   #2
TSEJEEPERS
Somewhere in the $200 range. With a air tank.
You plan on using the stock pump so make sure you spend the money for a decient check valve and air lines. You also want to run a copper line in between the rubber hose and the compressor. The air coming out of the compressor gets pretty hot.
I run mine out to the air tank first, to help cool it down and keep the oil out of the system, then to the filter and regulator.
My check valve is after the copper line. It is one that is used for air not for water.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 11-28-2009, 06:27 PM   #3
ZeroGravity
ZeroGravity's Avatar
You could probably piece it together with a junk compressor for the tank if you're looking for a way to save.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is online now   Reply With Quote
Old 11-29-2009, 09:22 PM   #4
wzrroc
ok good that's within my budget. Thanks!
Glock Forum
