06-19-2012, 05:51 PM
#16
2000 with 165,00 and ticking...hope it stays alive till I can afford a 1.9tdi swap
06-19-2012, 08:07 PM
#17
98 with 175,000 and still running fine. Needs to get me through the Jeepers Jamboree in july, then its getting a 5.3!
06-19-2012, 08:08 PM
#18
2.5 miles
hello my little 2.5 has 260000m runs like a top won't DIE
06-20-2012, 01:39 AM
#19
170k
2001 5 spd
06-20-2012, 02:12 PM
#20
92 with the 2.5 has 141,xxx still ruining strong.
06-20-2012, 03:06 PM
#21
1991 with 156K plus 10% for the oversize tires. Original needs a timing chain starting to get a bit noisy
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
91 YJ 2.5L 5-spd, 31" BFG ATs, mostly stock NO RUST 160K in WNY, Daily Driver
06-20-2012, 04:07 PM
#22
320,000 Km on mine when i had to do a motor swap due to excessive oil burning.
not sure how many on the 2.5 i put in but its from a 90 cherokee
06-20-2012, 05:11 PM
#23
Just turned 144k runs good but need to get the exhaust fixed. Previous owner broke 2 maifold bolts off in the head changing the manifold. I hope the shop can fix it next week. I still drive it everyday just sounds like a pulp wood truck and the check engine light is on.
87 wrangler on 33s
97 wrangler with RE lift on 31s, locked in the rear
05 turbo busa-381rwhp @ 22lbs of boost
2000 jeep grand 4.7 awd stock wife's dd
06-20-2012, 08:32 PM
#24
Wife's TJ has 177K and still running good. Had 28K on it when we bought it back in late 97.
Driven every day.
06-20-2012, 08:37 PM
#25
95 with 118k
06-20-2012, 08:40 PM
#26
I am assuming about 104K miles considering the beast has had big tires on it most of its life, without speedometer re-gearing. Spits oil out, but runs smooth, like a timex.
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
L.E.D. Guru
06-21-2012, 05:54 AM
#27
208k here
89 Jeep Wrangler - 3.5" HD BDS lift and M.O.R.E. HD 5/8" booms on 33s
72 Chevy Nova - build in progress
98 Pontiac Grand Prix GTP - too many mods to list::SOLD::
06-21-2012, 02:37 PM
#28
seeing some high # good to know the are dependable
Michael Garrett
1987 YJ - sold, 1995 ZJ - sold, 1998 XJ - sold, 2000 TJ
06-21-2012, 03:38 PM
#29
 An 87 2.5 shouldn't have a check engine light. It only has an "EMIS MAINT" light. And that's just turned on by a timer under the dash for you to take the jeep to the stealership so they can sell you an O2 sensor. If you look on the firewall under the dash, you'll see a clear box next to the gas peddle. Unplug it and the light will go away.
"Anything to do with the land, I love."
"So it's probably eighty percent luck and twenty percent skill."
-Chris LeDoux
I never could figure what the sky was thinking, but the soil, she don't keep too many secrets.
06-21-2012, 03:58 PM
#30
Sorry it's a 97 tj. I just bought the jeep. I havnt updated my profile
87 wrangler on 33s
