How to get my Jeep ready for storage - JeepForum.com
post #1 of 6 Old 07-23-2013, 03:20 PM Thread Starter
kjmccar
I am going to college in 3 weeks. I am leaving my jeep home for the first semester and it will not be driven at all.
What do I need to do to make sure that it will run fine after I store it for a while.
Another thing is that my Jeep will need an oil change right as I leave. Should I do the oil change before I leave, after I come back, or does it not matter?
Thanks, guys.
kjmccar is offline
post #2 of 6 Old 07-23-2013, 03:37 PM
frenchy206
A semister isn't that long. I'd put a trickle charger on the battery and that's about it. Will it be outside or in a garage?
03 TJ Rubicon
frenchy206 is offline
post #3 of 6 Old 07-23-2013, 05:19 PM
OlYellerTJ
As pointed out, a semester isn't that long. If you can, have someone start it up and take it for a spin, enough to work it up to operating temp (including the exhaust) once a week or two. If you can't, and you don't have a trickle charger, just unhook the battery so the electronics don't drain it over the quarter (radio presets and clock, for instance). Put fuel injector cleaner in with the last tank of gas when you top it off before storage. It is a better gas preservative than Sta-bil, as per the advice of the power equipment dealer who rebuilt my snow thrower's carb and fuel system a few years ago. No rebuilds since, and it starts on one or two pulls every time, I think I used it three days this past winter--cleaning up after a single block-buster Nor'easter dumped 3' on us (one day for each foot?!). For such short term storage, IDK if putting it up on jack-stands is worth the effort to prevent flat spots forming on the tires from sitting. I don't think I'd bother but someone with more experience or knowledge than I might chime-in.
Good luck at school!
Ol' Yeller TJ
This message is composed of recycled electrons. None of the electrons was harmed or injured in the creation of this message but they have been shamelessly exploited for this use.
OlYellerTJ is offline
post #4 of 6 Old 07-23-2013, 08:16 PM
2jhanna
I would do the oil change if your due. Rather have it sitting with new clean oil instead of old dirty stuff.
And like asked above, inside or outside. If outside, I would get some kind of cover to protect the finish and top.
jhanna
denton county, tx
2jhanna is offline
post #5 of 6 Old 07-24-2013, 06:46 PM
jokerchief462
Fresh oil change, disconnect the batter and a car cover. Check tire pressures and your off to college no problems.
When you return charge the battery overnight hook it up and away you go.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 6 Old 07-24-2013, 10:47 PM
frenchy206
About the car cover, be advised that you can trap moisture inside the Jeep if the cover is left on for long periods of time. My dad left a car cover on a newer mustang convertible for several months. When I took it off for him, opened the car up, there was mold everywhere. It was a pain in the *** to get rid of.
Best bet, keep it in a garage or rent a spot in a garage.
03 TJ Rubicon
