Honing cylinder help - JeepForum.com
post #1 of 11 Old 12-25-2011, 01:41 PM Thread Starter
beefcake3
these are groves worn in the top of my cylinders can i hone theses out or will i need to have them bored out???
the other cylinders have the similar story. I dont have any measurement tools so i cannot say how deep they are they can be felt slightly with your finger
beefcake3 is offline
post #2 of 11 Old 12-25-2011, 01:57 PM
222Doc
222Doc's Avatar
hard to tell with a pic, but honing is basically just polishing metal, looks like that needs to be bored if you can feel it and it looks like not just a top ridge. did you get the pistons out with out reaming it, break any rings? you rebuilding the bottom as well? hard to say with out checking details miking it in a few places.
222Doc is online now
post #3 of 11 Old 12-25-2011, 01:58 PM
ninjakid
1987 YJ Wrangler
Know anyone with a ridge reamer?
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #4 of 11 Old 12-25-2011, 02:09 PM Thread Starter
beefcake3
sadly i do not
post #5 of 11 Old 12-25-2011, 02:33 PM
JPi1
If you can feel it with your fingernail, it needs a bore. Since the ignition of the fuel happens at the top of the stroke, the condition of the upper bore is critical to power.
JPi1 is offline
post #6 of 11 Old 12-25-2011, 03:24 PM Thread Starter
beefcake3
Is it possible that I could hone it enough for the jeep to run untill I can find a new engine for it??
post #7 of 11 Old 12-25-2011, 03:34 PM
5-90
5-90's Avatar
1988 XJ Cherokee
May as well not bother - honing won't remove enough material to make a useful difference, if you can feel the ridges with your fingernail. You've got it torn down - I'd say to just strip the block and take it in.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 11 Old 12-25-2011, 03:40 PM
jay-h
Probably should be bored. If that is really out of the question, you could hone them as smooth as possible and put it back together with fresh rings. It will probably run ok for a while but won't really last.
jay-h is offline
post #9 of 11 Old 12-25-2011, 06:55 PM Thread Starter
beefcake3
Anyone eles have this problem??
post #10 of 11 Old 12-25-2011, 10:10 PM
Alabamaranger
Get a micrometer and measure the bore and see what the size is under the ridge. That will tell you if it needs to be bored or not.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #11 of 11 Old 12-25-2011, 10:42 PM
5-90
5-90's Avatar
1988 XJ Cherokee
If you can feel it, you're going to have to bore it.
You can strip out a ridge about .001-.002" (one side) height with 120-gr honing stones (I've done it a few times,) but it's hard to feel something like that unless you're got practise.
Typically, if you can feel it with your fingernail, you're looking at .003"-.005" on one side (total .006"-.010" defect,) and probably a bit more than that.
Typical overbores? You can find rings & pistons (yes, you'll need both to do a proper job) in +0.030" easily, with +0.010" being uncommon (but sometimes available, depending on application.)
Hone & re-ring? Perhaps - but I wouldn't count on it lasting more than it would take to source another block or pile up nickels to do the job right (call it six months at the outside...)
5-90 is offline
Honing Cylinder Liner? captjanes TJ Wrangler Technical Forum 1 02-26-2011 09:24 PM
Removing center console lock cylinder from latch cylinder Dstompe TJ Wrangler Technical Forum 11 06-27-2009 08:01 PM
Cylinder 2 misfire dead cylinder plenty of fuel Mel16m TJ Wrangler Technical Forum 10 11-27-2007 11:52 AM
Pinion bearing honing/cutting safarimike TJ Wrangler Technical Forum 4 10-27-2007 07:45 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 09:37 AM
