High miles? 100k? 200K? More? - Page 2 - JeepForum.com
post #16 of 28 Old 01-31-2011, 12:37 PM
Evian
62K so far on a 1999 TJ.
Evian is offline
post #17 of 28 Old 01-31-2011, 12:47 PM
PeteYJTJ
187K now on my 99TJ 4.0 5-spd. Doing fine. Repl. Radiator, steering box, steering shaft.
183 on my Jeepchick's 2003 Grand Cherokee. Only odd stuff I've had to replace on that have been both front window motors, the heater control panel, and the electronic fan relay.
My YJ has 200+ on it, but that kinda doesn't count. Rebuilt tranny, rebuilt motor, trans case, etc., etc. The frame and body definitely have that many miles.
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #18 of 28 Old 01-31-2011, 12:48 PM
squazz
Originally Posted by MONSooNmonkey View Post
hahaha you burnt out the tranny on a car with 300k doing burnouts? and then scrapped it?
twice smokem if you got em
oh it did not just blow it exploded
then i tried to blow the motor cut exhaust off drained oil and rad the held it to rev limiter for bout 30 minutes nothing would not die neighbor came out yelling "What the hell you doing making all that noise?" i said trying to get my money worth out of this car
squazz is offline
post #19 of 28 Old 01-31-2011, 01:01 PM
MONSooNmonkey
You're a moron.
Sadface :(
MONSooNmonkey is offline
post #20 of 28 Old 01-31-2011, 02:27 PM
squazz
You're a moron.
squazz is offline
post #21 of 28 Old 01-31-2011, 02:55 PM
mylightsrsquare
hahahaha sounds like something i would do
1988 yj. 4.2l with a Weber and an ax15 swapped in
mylightsrsquare is offline
post #22 of 28 Old 01-31-2011, 04:37 PM
Joshdale
I have around 260 on my '93 YJ 4.0L
Joshdale is offline
post #23 of 28 Old 01-31-2011, 05:44 PM
jay-h
210k on my 89, when I hit 200K I was on a 2700 mile road trip (it's not just a daily driver, but a travel vehicle too)
BTW folks, go over to allpar.com and signup for their 200K registry. We need more Jeeps represented.
jay-h is offline
post #24 of 28 Old 02-01-2011, 12:38 AM
otr1952
133k on 94YJ, 150K to go!!
Politicians are like Diapers, they get full of stuff and need to be changed frequently!
otr1952 is offline
post #25 of 28 Old 02-01-2011, 05:12 PM
04-rubi
Do the cherokees with the 4.0 use the same engine as the 4.0 wranglers?
04-rubi is offline
post #26 of 28 Old 02-01-2011, 07:24 PM
otr1952
yes
otr1952 is offline
post #27 of 28 Old 02-01-2011, 08:45 PM
Dead_End
1990 XJ Cherokee
Originally Posted by electroguy75 View Post
98 tj 2.5 with 277,000 kms.(just bought this one) I am rebuilding this engine (broken piston skirt #3 cylinder). rod bearings wore bad not sure about the mains yet, still have to remove the crank, but i suspect more of the same wear. This rig is destined for a frame off restore. cheers.
I just had to replace the #3 piston on my 2.5 last week because if a broken piston skirt. It wasn't really hard work at all. Just time consuming. 198k miles on it BTW.
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline
post #28 of 28 Old 02-02-2011, 09:16 AM
bige2533
Give me a couple years and I'll have my 99 there (172K).
bige2533 is offline
mileage , miles
Has anyone hit over 100k miles yet? MacK JK Wrangler Technical Forum 208 03-09-2016 04:26 PM
How many YJ's on this Forum have over 200k miles? trayson YJ Wrangler Technical Forum 73 09-18-2011 01:06 PM
How Reliable?: 97 4-banger with 200k miles GomerPyle585 TJ Wrangler Technical Forum 8 11-28-2009 03:33 PM
9 year old Stock springs with 100k miles = sag? Dekemonger TJ Wrangler Technical Forum 6 10-22-2006 09:22 AM
1992 Wrangler 200k miles for $6000 Huntersbo YJ Wrangler Technical Forum 22 09-21-2006 08:36 AM
