#1 | |
Hide-A-Key Location
Where would ya'll suggest for a Hide-A-Key location on a TJ? This is to help those with a hard top.
#2 |
NO DOORS no hidea key needed.JK I dont have a hiding spot sorry
#3 |
I don't tell that stuff.
But, I would not use magnetic hide-a-keys. Use an actual screw/nut/bolt though the key to hold it in place.
2006 LJ Claytonized 1999 TJ stockish 1987 J20 |
#4 |
Good idea bairy
#5 |
Just give it to me i will hide the key for you. |
#6 |
you could "zip tie" it almost anywhere. even inside the air filter housing, or even suspend it inside your coolant bottle.
jhanna denton county, tx |
#8 |
Do it right or not at all
![]() Join Date: Jan 2003
Inside the PDC (power distribution center) inside the engine compartment on the passenger side, in front of the battery. There's plenty of space inside there and I doubt any thief would look inside there for the key.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#9 |
A piece of copper wire thru the key tied somewhere under the JEEP
#10 |
don't use a magnetic hide-a-key. someone will find it.
I knew a guy, who knew a guy, who had a friend.....whatever....guy put his hide-a-key against the inside of the stock bumper. Good place right? His truck was stolen with that key.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#11 |
i used to put mine inside the center caps of my wheels. happy hiding!
Sienna Jeep Club: Member #2 ___ ___ [l_,[____], l---L - OllllllO- ( )_) ( )_)--)_) |
#12 |
Inside the fuse box under the hood. Especially since most people don't know that there's not a hood release inside the car.
--Grant-- 2002 TJ SE 2.5L 4cyl STOCK |
#14 |
I put mine under the hood under the brake booster, its black so can't really see it, and don't need to get inside to open the hood
#15 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
