Help. My instrument cluster won't work. - JeepForum.com
post #1 of 12 Old 04-13-2013, 05:42 PM Thread Starter
Jamesba
Hi. I have a 1997 wrangler and my dashboard cluster doesn't work right. The lights work but none of the gauges read. The circuit board looks good and I don't see any loose wires. What could I try?
Jamesba is offline
post #2 of 12 Old 04-14-2013, 08:34 PM
gunut
electrical problems can be a biotch...just keep looking
gunut is offline
post #3 of 12 Old 04-15-2013, 03:32 AM
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
Print out the wiring semantics and go from there. If your lucky it could be a fuse, relay, or even a fusible link if it has one...
ashland82391 is offline
post #4 of 12 Old 04-15-2013, 02:25 PM
Morris4x4Center
Morris 4x4 Center
Morris4x4Center's Avatar
1987 YJ Wrangler
There are fuses for the Cluster. Double check em and let us know! Anything been done to the Jeep as of late?
Jeep Parts and Jeep Accessories
Toll Free: 877.553.5337 | Free Shipping on Orders Over $75!
PM us for any questions.
Morris4x4Center is offline
post #5 of 12 Old 04-16-2013, 04:41 PM
Evian
Put both hands on the cluster and push it in. It probably has come a little loose. Mines did that to me once. It turned out to be that.
Evian is offline
post #6 of 12 Old 04-20-2013, 03:25 PM
Jonny Jeep
Jonny Jeep's Avatar
Check fuse 17 under the hood (constant 12V) and fuse 10 behind the glove box (switched 12V).
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #7 of 12 Old 04-20-2013, 05:30 PM
ashland82391
Originally Posted by jonny jeep View Post
check fuse 17 under the hood (constant 12v) and fuse 10 behind the glove box (switched 12v).
12.6 :-)
post #8 of 12 Old 04-21-2013, 08:14 PM
Trespasser
I give mine a nice whack on the top-right of the cluster every now and again when they cut out, but in my case it is only speed/tach/odometer that go dead. Fuel, temp, pressure continue to read normally. It actually happens a lot. Sounds like maybe a different issue though.
Trespasser is offline
post #9 of 12 Old 11-22-2013, 02:12 PM
frank5738
Guest
Posts: n/a
my 99 tj has the same issue, but only the temp and battery gauge work. ive changed all fuses, put new ground cables in. tried the whole squeeze the pins on the back of the cluster and got nothin. even put a new cluster in it and it still wont work. im stuck
post #10 of 12 Old 11-30-2013, 08:44 PM
Sthrn
Not sure if you are experiencing the whole instrument panel problem of tach and speedometer dropping and airbag light coming on but this is from my original bulletin after complaining to Jeep over and over again! This is a common problem with the Jeep wranglers that causes the gauges to have intermittent operation. Jeep has issued 2 TSBs about it. 08-15-99 is the latest and basically states that the male terminals on the cluster get corroded. There is a cleaning procedure and some small parts to get to correct the problem.
"TSB NUMBER: 08-15-99
GROUP: Electrical
DATE: May 21, 1999
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN NUMBER 08-20-98 REV. A, DATED OCTOBER 2, 1998, WHICH SHOULD BE REMOVED FROM YOUR FILES AND NOTED IN THE BOUND TECHNICAL SERVICE BULLETIN BOOK, PUBLICATION NUMBER 81-699-99003. THIS IS A COMPLETE REVISION TO THE PROCEDURE.
SUBJECT:
Erratic, Intermittent Cluster Operation/Intermittent Air Bag Warning light.
OVERVIEW:
This bulletin involves installing a repair harness containing a revised instrument cluster connector.
MODELS:
1998 - 1999 (TJ) Wrangler
1998 - 1999 (XJ) Cherokee
SYMPTOM/CONDITION:
Some vehicles may exhibit an intermittent illumination of the air bag warning light or an intermittent tachometer or speedometer drop out. An Airbag Electronic Control Module (AECM) fault code - "No Cluster CCD BUS" message will be present.
DIAGNOSIS:
Using the DRB III(R), read and record all active and stored fault codes in the AECM. This condition is caused by minor oxidation of the BUS circuit terminals at the instrument cluster connector. Electrical terminals will show signs of oxidation, which will appear as darkened lines or marks on the cluster male terminals. These often appear as gray or black marks rather than the appearance of oxidation or corrosion usually associated with higher current carrying circuits. This condition will set a "NO CLUSTER CCD BUS" message. The fault code will usually be stored and not active. THIS TECHNICAL SERVICE BULLETIN WILL NOT ADDRESS FUEL OR OIL PRESSURE GAUGE ISSUES. If this fault code is present, either active or stored perform the Repair Procedure.
PARTS REQUIRED:
1 05016261AA Cluster Connector Patch Harness
1 04856975 Electric Contact Cleaner
2 04778570 Heat Shrink Tubing
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: 08-90-90-91 0.6 Hrs. "
Sthrn is offline
post #11 of 12 Old 11-30-2013, 08:51 PM
Sthrn
AND to back up Trespasser...A nice whack on the top of dash works to bring the tach and speedometer back, for awhile
Sthrn is offline
post #12 of 12 Old 07-15-2015, 06:18 PM
wadewen
wadewen's Avatar
Here's a helpful hint. When you pull fuse 17 under the hood and walk into the parts store with it to buy one, don't put the new fuse in the unused fuse 19 spot. Ouch!
wadewen is offline
jeep , wrangler
