Help with '89 4.2L Vacuum Hoses - JeepForum.com
post #1 of 6 Old 05-09-2013, 09:13 AM Thread Starter
trackingfast
I am having trouble getting my '89 YJ 4.2L started. At one point I had very few problems, and then they became intermittent and now I can't ever get the YJ started. There are two disconnected vacuum hoses that I am not sure where they go. I have looked at various diagrams but not found the correct spot.
I have adjusted the screw on the front of the carb, which previously helped a lot.
I have cleaned the carb, which also previously helped.
I am convinced that I should switch to a Weber Carb, but I am not sure if switch the carb will completely work, or if I should have someone look over the current system first?
Does anyone have any advice?
Any mechanic suggestions for the Madison, WI area?
Thank You!
trackingfast is offline
post #2 of 6 Old 05-09-2013, 10:47 AM
dancytron
post on the YJ tech board with a lot more details.
dancytron is offline
post #3 of 6 Old 05-09-2013, 05:12 PM
ad-man
1989 XJ Cherokee
Can you post a picture of them? Where they come from? I could go and take a picture of my 87 and see if that helps. They may go where the ones on mine go.
Let me know
ad-man is offline
post #4 of 6 Old 05-21-2013, 01:10 PM Thread Starter
trackingfast
I appreciate your feedback but, I think I figured it out. Although I think I am still going to use a weber carb, my jeep is running.
I did increase the idle which does seem to help, but I think maybe part of the problem is a leaky jet that can flood the carb depending on how I park.
Thank you again
post #5 of 6 Old 05-22-2013, 11:56 AM
1222
RIP John
1222's Avatar
Does your carb have the “stepper motor”, if so that just might be your problem? It is common for those to go bad and will give you the problems you are describing.
1222 is offline
post #6 of 6 Old 05-23-2013, 08:09 AM
jay-h
The stock carb is not great, but the Jeep should run reasonably well if all is set up properly.
The Weber is better but not a cure all.
I converted to FI and have a bunch of parts. Pm me if you need something.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
