-   Wrangler General Discussion (http://www.jeepforum.com/forum/f176/)
-   -   Hellppp (http://www.jeepforum.com/forum/f176/hellppp-1519250/)
offroadnick 05-05-2013 07:52 PM
Hellppp
Y would one directional blink slower then the over side but whn the hazards are on the are normal im so confused
Maverickxeo 05-05-2013 08:05 PM
A bulb is burnt out. Check the taillights and signal lights on the side that blinks faster. :thumbsup:
2jhanna 05-05-2013 08:53 PM
I agree with above. Compare both sides and look for a difference. Don't forget side markers. Also do it with lights on and off.
offroadnick 05-06-2013 10:40 AM
No one blinks normal and one blinks like 2 every 30 seconds and no lights r out
NonRubicon 05-12-2013 04:18 PM
Check the grounds and wires on that side. Sounds like you have corrosion somewhere.
As I understand it, the turn signal relay is a thermal relay - it uses current+resistance to heat a wire which closes the turn signal circuit, lighting up the lamps. Closing the relay cuts power to the resistance wire, cooling it, thus opening the circuit and the lamps go off. It continuously repeats this cycle to provide intermittent flashing turn signals.
For any given voltage, the more you increase the resistance, the less current you get. Corrosion increases resistance, and lowers current. Lower current will take longer to heat up the wire and close the thermal relay. This would slow down the rate of flash.
A very simplified diagram of a turn signal setup:
http://static.ddmcdn.com/gif/turn-signal-wiring.jpg
You know the flasher relay works for one side. So your problem lies somewhere after the relay. Maybe corrosion in the turn signal switch or wiring or grounds on the problem side.
:cheers2:
The time now is 04:09 PM.
