Have FUEL spill problems like MANY of us? Submit a complaint to force a recall!!! - Page 4 - JeepForum.com
post #46 of 992 Old 02-18-2010, 12:00 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
mine has done it since it was new, i'll be submitting
My builds:
and
or follow us on
spyder6 is offline
post #47 of 992 Old 02-18-2010, 12:04 PM
protix
Youve got to have enough money to fill up your tank for this to happen by the looks so i think im safe
protix is offline
post #48 of 992 Old 02-18-2010, 12:04 PM
mJUSTINm
thats weird. you're lucky the pump even flows gas with the handle locked into place. mine stops every 5-10 seconds, so i have to hold the handle about half way up to get it to flow without stopping.
-Justin
mJUSTINm is offline
post #49 of 992 Old 02-18-2010, 12:07 PM
suesjeep
Just an FYI- in addition to filing a complaint, I called my dealer and the service manager told me he's heard of it a only couple of times. I followed Sgt Utz cue and contacted a news outlet asking them to consider a story.
suesjeep is offline
post #50 of 992 Old 02-18-2010, 12:34 PM
rmeredit
Boo f'in hoo... ;-) Just stop it when you hear it coming up the neck. BTW - those are the most boring videos on YouTube, congrats OP.
rmeredit is offline
post #51 of 992 Old 02-18-2010, 12:53 PM
Kulae
Kulae's Avatar
2006 Wrangler "LJ"
Been spilling over since about Jan 2008. I've probably contributed about 5 gallons back into the earth to be dug up later and resold.
That's just it to, at least for me, there are no warning signs. You just have to know about how much you need in there to stop it and slow down the fill rate.
2006 Jeep Wrangler Unlimited Silver with a 6 Speed Manual
Jeeperman Winch Ready Front Bumper with Mile Marker PE8000 and 150W KC Daylighters
Body Armor Rear Bumper Swing Away and Matching Rocker Guards
Skyjacker 2" BB, 1.25" JKS BL and 1" JKS MML
75 WX ST CB radio with a 4' Firestik antenna
1.5" Seat risers custom made
33x12.5x15 BF Goodrich T/A and Procomp Rockcrusher Series 99 rims
Kulae is offline
post #52 of 992 Old 02-18-2010, 12:56 PM Thread Starter
Sgt_Utz
Sorry it didn't have action and pretty pictures. They're there for informational purposes, not entertainment. They're not my videos btw... If u had this issue you too would b annoyed.
Now to the one earlier who yelled at the worthless posts, his is the first one...
Sgt_Utz is offline
post #53 of 992 Old 02-18-2010, 01:04 PM
suesjeep
I was ahead of my time...haha
suesjeep is offline
post #54 of 992 Old 02-18-2010, 01:34 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
only does it at certain gas stations for me...
Jamison
ajamison is offline
post #55 of 992 Old 02-18-2010, 01:39 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
i tried submitting, but the site seems to be having some issues. ill try again later
Jamison
ajamison is offline
post #56 of 992 Old 02-18-2010, 01:47 PM
Kulae
Kulae's Avatar
I was using Safari, I had to use IE to get it to work.
Kulae is offline
post #57 of 992 Old 02-18-2010, 01:48 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
okay thanks, im using chrome.. i'll try IE
Jamison
ajamison is offline
post #58 of 992 Old 02-18-2010, 02:26 PM
cheech66
submitted and done complaint had problem since 08 on my unlimited 06
cheech66 is offline
post #59 of 992 Old 02-18-2010, 02:33 PM
GeoKR
Man that sux, my 98 has never done it. I even hit the lever a few more times after it clicks. But if it did I would surely be pissed about it.
98 Sahara 4.0 5spd - 5" W/ 35" Boggers, Rubi 44 Front Locked & Chromo'd w/ 5.13's, 8.8 Rear Locked w/ 5.13's, NV241OR, Woody Shafts, Flat Skid, Tuff Designs Front Bumper, EPi9.0 W/ Blue steel
I spent most of my money on women, booze, and toys, the rest I just wasted.
GeoKR is offline
post #60 of 992 Old 02-18-2010, 03:06 PM
NorCalCon
X2 for me hard to get gas to go in at many gas stations. Every pump is different. Some pumps will cause the fuel to spray out when the tank is full. Other pumps wont let me lock the trigger in the on position. Normally I too hold the trigger half way down while fueling to control the flow of gas into the tank. Too much flow and the trigger clicks and stops the fuel flow. I've got a BL and it had the problem before the body lift. The first time it sprayed gas back at me I wasnt expecting it and got gas all over my clothes. Could have been a problem if there was an ignition sourse. Especially sense the back spray is a fuel, vapor and air from the gas tank mizture. Anyways I submitted a complaint through the website and called. There was a message that they have a high volume of complaints due to the Toyota recalls.
NorCalCon is offline
Fuel spill EVERYTIME I fill up my Jeep now Sgt_Utz TJ Wrangler Technical Forum 43 04-11-2013 06:04 AM
How many have filed a complaint on the fuel tank? Orrin JK Wrangler Technical Forum 86 03-31-2010 04:04 AM
Major vacume in fuel tank causing fuel to spill out bigredcherokee YJ Wrangler Technical Forum 2 09-28-2008 02:35 PM
Fuel sending unit recall? esad_b TJ Wrangler Technical Forum 13 06-09-2008 08:24 AM
Fuel Spill Jim Piszar YJ Wrangler Technical Forum 11 10-17-2007 11:10 AM
