Quantcast Have FUEL spill problems like MANY of us? Submit a complaint to force a recall!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Have FUEL spill problems like MANY of us? Submit a complaint to force a recall!!!
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 02-18-2010, 12:22 AM   #1
Sgt_Utz
Sgt_Utz's Avatar
I voiced a complaint in another thread that my tank overflows everytime I fill up the Jeep. Apparently this is a very common problem and Chrysler refuses to do a recall. ChicagoRod was kind enough to post a link to formally submit a complaint to the Defects and Recalls for the National Highway Traffic Safety Administration. The videos below are also from him.
I'm asking that all who have this issue to clink on the link below and fill out the form. Many of us know they only look at repeat complaints so we need a lot of complaints for this issue, not just a few of us. For those with accounts on other Jeep sites if you could please create a thread there to get the word out to as many Jeep owners as possible. This thread has also been created on WAVJC.org.
Thanks all, and please post if you created another thread or filled out the form. I'm sick of dumping fuel everytime I fill up and refuse to pay Chrysler for another defective tank! There's multiple threads on this issue and it's time we act instead of *****. If anyone knows of another way to get the government to look into this issue please let us know...
SUBMIT COMPLAINT HERE
(Skip to the last 20 seconds of the videos... They're not edited)
or?
or in a new JK?
Does your gas tank overflow at the pump? SUBMIT COMPLAINT HERE!
Originally Posted by IPA View Post
"See, I told you so." - Thomas Jefferson, 2011
Sgt_Utz is offline   Reply With Quote
Old 02-18-2010, 12:34 AM   #2
jdub2k5
O I would be so pissed if my jeep did that
99 TJ 4.0l 5speed, 4 inch suspension 3 inch body, 35 bfg km2 tires
jdub2k5 is offline   Reply With Quote
Old 02-18-2010, 12:58 AM   #3
Sgt_Utz
Sgt_Utz's Avatar
I wonder if it's only on newer TJ's and JK's. Yours being a '99 I would think it would have done it by now. Lucky you
Old 02-18-2010, 01:11 AM   #4
tjwoo
thanks for doing this, but good lord. You could have told us to skip to the last 10 secs of each video.
tjwoo is offline   Reply With Quote
Old 02-18-2010, 01:17 AM   #5
Sgt_Utz
Sgt_Utz's Avatar
Noted and suggestion was added to the post. Thanks! Are you submitting a complaint?
Old 02-18-2010, 01:19 AM   #6
tjwoo
you betcha. 90% of the time I stop a bit early to prevent it from happening, but if i just let it fill up, gas comes gushing out every time.
by the way, nice jeep color
Old 02-18-2010, 01:22 AM   #7
Capricorn
Mine does that too, and its a 99. It only does it every 6th or 7th fill up...
2002 Grand Cherokee Limited
http://ddoffroad.com/
Capricorn is offline   Reply With Quote
Old 02-18-2010, 01:27 AM   #8
Sgt_Utz
Sgt_Utz's Avatar
Interesting. So this issue is hit or miss depending on the Jeep.
Filing a formal complaint?
Old 02-18-2010, 01:27 AM   #9
mightydog78
hmm i have yet to have this problem.. could it be from body lifts?
UNC-Charlotte
Mechanical Engineering
mightydog78 is offline   Reply With Quote
Old 02-18-2010, 01:28 AM   #10
Sgt_Utz
Sgt_Utz's Avatar
I have a JKS 1" BL on my Heep and it didn't fix the issue. You're just one that is lucky, so far...
Old 02-18-2010, 02:02 AM   #11
jwb4786
I havent had this problem... I have a 98 with no BL, although I am about to install a 1.25'' BL.
jwb4786 is offline   Reply With Quote
Old 02-18-2010, 02:07 AM   #12
97casteeltj
hmmm...mine never does that.
needing a new rig....
97casteeltj is offline   Reply With Quote
Old 02-18-2010, 02:17 AM   #13
SDGwheelin
My 06 LJ has done this since I owned it. Stock, with a lift, doesn't seem to matter. After awhile I just stopped filling it all the way up and that works for me, but I'll submit a complaint to help you guys out.
SDGwheelin is offline   Reply With Quote
Old 02-18-2010, 06:08 AM   #14
Bmel17
mine used to do it all the time, but stopped. I use fuel system cleaner every 2 months or so. Even if I'm not running the TJ that much (not my DD anymore). And I seem to let the tank get very very low before each fill up usually. I've heard the problem was due to air pockets in the tank. Well whatever it is it stopped for me.
06 TJ Black GOLDEN EAGLE Edition
03 VW 1.8T Jetta DD
08 HD Nightster
Bmel17 is offline   Reply With Quote
Old 02-18-2010, 06:16 AM   #15
Bennettj13
I'm a big meanie head
Bennettj13's Avatar
Mine never did it until after it was heavily modified. I'm sure it was my own fault. Once I re-located the filler neck it started happening.
::SELLING::
Bennettj13 is offline   Reply With Quote
Glock Forum
