Hardtop Insulation - JeepForum.com
post #1 of 7 Old 11-04-2012, 07:35 AM Thread Starter
chodge40
Hardtop Insulation
Looking for something cheap to insulate the Hardtop with than spending $500 on insul-lining. Any ideas? Thanks
chodge40 is offline
post #2 of 7 Old 11-04-2012, 07:59 AM
Eron
Are you looking for sound or to keep it warm? Probably both i assume.You could use that Dynomat stuff, but its really expensive. When i was roofing we used a product called " Grace " Just like Dynomat. But for like $100 you could get a 4'x8' sheet. That would help with the sound aspect of it. But am not sure about keeping it warmer.
Eron is offline
post #3 of 7 Old 11-04-2012, 08:42 AM
Ironhead
the foam insulating sheets are very cheap. do some cutting and get some spray adhesive, paint one side and install.
what kind of jeep? both TJ's and YJ that i have owned have had sick heaters, cab was warm in minutes, even with a soft top
Ironhead is offline
post #4 of 7 Old 11-04-2012, 09:24 AM
sdotcarter
Go with foam. Flip your top upside down so you can work in it.
Get a nice pair of scissors (I dropped $75 on a pair)
Clean your top with soap and water, remove all the hardware
Cut your foam. In the corners cut a 45* angle and the two pieces will overlap. Cut them equally down the middle. It should make a pretty good seam, now tape both sides. Once you are done with it spray your top with adhesive and kind of roll it on. I went front to back. Since the area above the cockpit is pretty much square it provided a good place to start.
Let the foam bond with the adhesive for a day.
Go get some thin black carpet and apply it over the foam using the methods above.
Take you 3-4 days to do it right. Not including scissors I spent about $150 and that includes two rolls of tint.
Picture to show because I did something similar.
sdotcarter is offline
post #5 of 7 Old 11-04-2012, 12:24 PM
Eron
Wow...that looks great. Hows it handle sound? Heat is of no issue as my heater is almost too much.
Eron is offline
post #6 of 7 Old 11-04-2012, 12:43 PM Thread Starter
chodge40
That's does look awesome but not wanting to spend a lot on money and time. Heater is ok but takes a bit to warm . Not to worried about sound... Thanks for the input
chodge40 is offline
post #7 of 7 Old 11-04-2012, 03:40 PM
RiponredTJ
Happy Member No. 1
RiponredTJ's Avatar
Simple solution. Don't bother.
I drive around with the window cracked even when it's 30 below.
This City is what it is because our citizens are what they are.
RiponredTJ is offline
