Hard Top Hoist Build - JeepForum.com
post #1 of 16 Old 05-29-2013, 11:10 AM Thread Starter
Airborne Lee
Airborne Lee's Avatar
1 x 10 foot super strut $25
1 x harbor freight 250/400 lbs hoist $99
4 x 2 inch 3/8 lag screws
20 x 1 inch 3/8 washers
1 x shackle 3/8 all hardware was under $6
2 x 14 foot cargo straps $18
I used the lag screws to place my 10 foot section of strut across (perpendicular) to the garage ceiling 2x6 joists, in line with my jeep. I used one lag screw in each of the two 2x6ís at each end of the strut so that the center 5 foot of the strut allows the hoist to slide back and forth. This allows me to slide the hoist over the JK, attach the straps, then lift the top up, then slide the top back several feet away from my parking spot in the garage.
I used one washer inside the strut for the head of the screw and the other 4 washers per screw between the strut and the garage ceiling. This allowed me to keep some spacing between the strut and the ceiling so the hoist would slide.
Tricks:
1, Grease the strut in the center so it will slide under load.
2. Make sure the hoist you use has mounting brackets that fit the strut.
3. Slide the hoist several times to clear out the evil popcorn finish on the garage ceiling so it doesnít come down in your eyes.
4. Donít tighten the lag screws so tight that they crush the sheetrock ceiling and press the strut too tight against the ceiling, or you wonít be able to slide the hoist.
5. The center of gravity on the roof is only a foot from the glass door. (That was a surprise).
Issues:
1. I still have to have to be very careful when driving out from under to back under the lifted top to ensure the top does not turn or get bumped by the roll cage and swing.
2. A twelve foot section of strut would have been better to get 6 total 2x6ís in the ceiling rather than just 4.
3. I may go up in the attic and add a brace between the joistís to run along the strut and allow me to add more lag screws.
'16 JKU Rubicon, Tan, RR Front Bumper, 9500i, Atlas Rear w/Tire Carrier M416 Trailer
Airborne Lee is offline
post #2 of 16 Old 05-29-2013, 12:03 PM Thread Starter
Airborne Lee
[IMG][/IMG]
[IMG][/IMG]
post #3 of 16 Old 05-29-2013, 12:04 PM Thread Starter
Airborne Lee
post #4 of 16 Old 05-29-2013, 12:05 PM
Deuskid
good job
Deuskid is offline
post #5 of 16 Old 05-29-2013, 12:47 PM
jefbob
Would you trust this to hold your hard top over your Jeep for a whole summer while running a soft top? Until now getting a hand removing my hard top hasn't been an issue since I have several friends and family members within minutes of my house, but we're moving a bit further away and my wife can't really help with my hard top because of the size. I'm trying to figure out how I can set myself up to put it on for the winter and take it off for the summer alone.
jefbob is offline
post #6 of 16 Old 05-29-2013, 12:49 PM
AlbertaJeeper
Good work! This is first on my list as soon as I get back from Moab! Probably going to go with a hand crank to lift it all up though. Is it just connected by straps, or do you have some kind of frame under the top?
AlbertaJeeper is offline
post #7 of 16 Old 05-29-2013, 01:21 PM Thread Starter
Airborne Lee
I have taken it off and replaced it 3 times now. Yes, I do trust the configuration but I dont trust my 1972 home construction. So I AM going to re-enforce it in the attic by adding a crossmember between the two joist's at each end of the strut! Then I can put two more lag screws on each end, 4 on each end total. The strut can take way more weight than the hoist.
My issue with long term storage is that the straps I'm using are too narrow and I fear damage to the rubber weather stripping on the top itself. I'm looking at hooks or wider straps for long term.
As for long term storage like this, Yes it would be ok but it is still a hard top hanging in the middle of the garage so it is still in the way.
This hoist lowers the top all the way to the ground where it could be put on one of those carts and rolled away. It would still be a solo job.
I have three helpers in my own house, still a PITA to get help! So I had to make this a one man job. I can do it in 1 minute longer than it takes to remove the bolts from the top! Seriously, the hardest part is backing the jeep into the garage and not hitting my bikes hanging on the side!
Just straps alone! for now! I should have gotten wider straps, 16 foot 2 inch wide tow straps would be perfect. Home depot had them for $22-24 each. then you would need two more lockable shackles or screw closed D-Rings.
I am ok with the straps as long as I'm not damaging my weather stripping.
I looked at the $29-50 hand cranked lifts, my issue, and it is a big one; is control lowering with the top on the lift. Lowering it while cranking means I'm against the wall turning the crank, hoping I don't drop it. with the electric lift button, I have one hand on the top while lowering it and lining up the holes. Also, a hand crank lift on the wall connects to a single 2x4 stud rahter than 4x 2x6's no hand crank on the wall can ever be as secure. But it could work...
post #8 of 16 Old 05-29-2013, 02:00 PM
jefbob
Thanks for your input. My new house the garage ceiling is drywall about 12 foot high, so honestly it would be cool to find a solution I felt comfortable with it hanging over my Jeep. That saves floor space! But I do have a storage dolly so if I implement this (or something like it), I'll just make sure the cable length is enough to get it to the floor to also get the hard top on the dolly.
jefbob is offline
post #9 of 16 Old 05-29-2013, 02:29 PM Thread Starter
Airborne Lee
That lift from harbor freight has a 38 foot cable. doubled over for 400lbs capacity you are totaly fine! You loose a foot to the height of the hoist, mounting brackets and strut and two foot for the top itself so you only need cable for 9 foot. But on second thought, it comes with a thin 1/8 inch cable. There is room on the spool for 3/16ths cable for the same or close to it length. If your worried about strenth it is another option for someone wanting to leave it up year round. or even better add eyelets to the ceiling on either side and slip load bearing straps under the lift/top at ceiling height and lower the top back on to the straps so the weight is on the straps not on the lift for the summer. For now, I have been lowering the top to the floor while I'm out. Over this last holiday weekend I left the jeep in the garage all week end with the top lowered on the jeep unbolted but still connected to the lift. Having said all of that, I know rationally there is no issue leaving it up for long periods of time, but I'm thinking of doing this because I am a safety freak and I don't have 2k to get a new top if something goes wrong.
post #10 of 16 Old 05-29-2013, 07:50 PM
jefbob
Thanks for more feedback. I'm a bit of a safety freak too when it comes to my Jeep. I don't want to end up with a hard top falling on it in the middle of the summer. So I'm most definitely going to keep all your thoughts in mind and concoct some storage solution. Honestly I'm currently sitting here thinking about doing what you've done and having some kind of strap backup. But, I don't get to move into the house for a week, so I'm sure once I can actually be in the garage and get my bearings straight, I'll come up with a good solution.
jefbob is offline
post #11 of 16 Old 05-29-2013, 07:54 PM
zenman
Quite a few youtube videos on this.
New Jeep: 10th Anniversary Rubicon, Anvil with Red Leather seats
Old Jeep: 2012 JK Sahara Dozer
zenman is offline
post #12 of 16 Old 05-29-2013, 10:39 PM
AlbertaJeeper
That's a good point, having something to guide it in might help, I'll have to see what I can find for pulleys to slow it down maybe
post #13 of 16 Old 09-10-2013, 04:23 PM
Deuskid
Airborne Lee,
Now that you've had this up for a while, what is your thoughts?
Would you change, add anything?
I am about ready to do something like this.
Thanks,
john
Deuskid is offline
post #14 of 16 Old 09-10-2013, 05:34 PM Thread Starter
Airborne Lee
Originally Posted by Deuskid View Post
Airborne Lee,
John,
Taller ceiling!
I would have put it farther back in the garage than where I normally park. Right now the top sits exactly above where I normally park. I should have pushed it back 5 feet farther. I can push it (slide it) back on the strut but I don't do that much out of fear of making it swing. But mostly I use the 5 foot of play I have for centering the top when I put it back on. I can pack forwards of backwards directly under the top but my ceiling is a foot to low to walk under it without ducking.
Other toughts...
longer lag screws. should have used three inch lags.
I put a lag screw in two crossing ceiling joists at each end of the strut.
This takes up nearly two feet on each end. I should have done some blocking in the ceiling to take up less lenght of the strut.
post #15 of 16 Old 04-25-2014, 01:45 PM Thread Starter
Airborne Lee
Update.
One year later...
Still solid. had to run the top down to the floor a few times to get the wire un-bunched up.
Need to lengthen the bar to allow me to slide the top back and forth more that the useable few feet.
The entire thing is still 2 inches too low. I keep hitting my head on the damn thing when I'm working on something nearby and have to look down a lot. Stupid I know, but it is just right there still in the way.
Looking to attach the end of the cable at the end of the strut rather than back to the hoist so that I can use the full 6 inches lost with hooking it to itself.
Oh yea, and most importantly, I still need to make a better hook for holding the top. the strap thing works but I think it adds a lot of time in getting the top OFF.
