hack n tap - JeepForum.com
post #1 of 10 Old 12-02-2011, 06:00 PM Thread Starter
muddr1
hack n tap
I have seen this on craigs list, not that I would buy one, but, what is a hack n tap sye kit. ????
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #2 of 10 Old 12-02-2011, 06:40 PM
Raimy
A style of sye that doesn't replace the slip yoke with a fixed. Instead you cut and drill, and tap the end of the slip yoke to bolt on a fixed converting it.
Raimy is offline
post #3 of 10 Old 12-03-2011, 09:29 AM
40dog
so how do they hold up ? anyone with a hack and tap? pro's / con's of hack and tap sye. tell us more!
40dog is offline
post #4 of 10 Old 12-03-2011, 10:53 AM
bill8bud
I have one from RE it is has been doing the job. It is on my short list of items to change since I removed my 35.
bill8bud is offline
post #5 of 10 Old 12-03-2011, 10:57 AM
muddyjeep36
They work fine you don't have to pull the transfer case. Been running one for about 10 years most of the time with 36" swampers.
muddyjeep36 is offline
post #6 of 10 Old 12-03-2011, 06:22 PM
Maverickxeo
So Im a little confused... you DONT need to do anything on the T-Case? Just swap out the driveshaft? Does it cure vibes?
Maverickxeo is offline
post #7 of 10 Old 12-03-2011, 10:35 PM
bill8bud
The instructions for the Hack and tap actually have you pull the transfer case output shaft then cut in tap it. I actually cut mine while it was still in the transfer case with a cut off wheel. The reason the hack and tap is not as strong as a regular SYE is because you drill and tap a hole for a bolt to hold the plate on.
bill8bud is offline
post #8 of 10 Old 12-04-2011, 07:39 AM Thread Starter
muddr1
Thanks, I was wondering why they were cheaper than a regular style sye kit.
Albert Einstein
muddr1 is offline
post #9 of 10 Old 12-04-2011, 08:19 AM
muddyjeep36
I pulled the driveshaft cut the output shaft and tapped with it on the vehicle then replaced the driveshaft. It's very simple to do all you need is a few hand tools, drill and a 4.5" grinder with a cut off wheel.
post #10 of 10 Old 12-04-2011, 03:38 PM
Hillbilly88
2014 JK Wrangler
I might have to try this way since im not really ready to spend the money on a complete kit. I have a old t case with messed up shaft to practice on. That way i know exaclly what to do
Hillbilly88 is offline
Hack and Tap cdalfson TJ Wrangler Technical Forum 4 03-06-2008 12:05 PM
hack an tap hotnutz TJ Wrangler Technical Forum 18 01-23-2006 05:54 PM
Hack N Tap vs MML gunnerdog TJ Wrangler Technical Forum 11 09-15-2005 11:04 PM
RE Hack & tap sbninja TJ Wrangler Technical Forum 12 09-14-2005 05:45 PM
RE hack & tap SYE jaburk TJ Wrangler Technical Forum 3 09-01-2005 02:52 AM
