Going to look at a 1995 Jeep Wrangler YJ Rio Grande what else should I look for? - JeepForum.com
post #1 of 9 Old 07-01-2010, 03:52 PM Thread Starter
gr33ng0bl1n
I am looking at the below jeep.. anything else I should check for?
2.5L 5 speed
Only 64,000 miles
4.5 Inch Rubicon Express Extreme Duty Lift Kit (1 year old) Rubicon Express 4.5" Extreme-Duty™ Suspension System for 87-95 Jeep® Wrangler YJ - Quadratec
2 inch body lift
35 inch Tires in good condition (4 + 1 brand new matching spare)
Slip Yoke Eliminator (SYE)
Sway Bar Disconnects
Front Custom Bumper
Rear Custom Bumper with tire carrier
Tuffy Center Console Tuffy 033-01 - Tuffy Stereo Security Console (10" Wide) for 76-90 Jeep CJ-5, CJ-7, CJ-8 Scrambler & Wrangler YJ - Quadratec
Warrior U-Bolt skid plates Warrior Products 1750 - Warrior Products Rear U-Bolt Skid Plates for 87-95 Jeep® Wrangler YJ - Quadratec
Warn Winch
ARB Snorkel ARB SS1000HF - ARB Safari Snorkel for 91-95 Jeep® Wrangler YJ with Fuel Injection - Quadratec
6 inch ARB Fender Flares
ARB Air Compressor (for lockers and filling tires)
Optima Red Top Battery
2 tops: Best Top Soft top (no leaks) and Best Top Bikini Top, Wind Jammer, tonneau cover
Brand new cat back exhaust
Front Axle -
ARB air locker ARB RD102/RD69 - ARB Air Locker Locking Differential for 27 Spline C Clip Dana 35 with 3.54 and Numerically Higher Gear Ratio - Quadratec
4.88 gear set (correctly geared for 35 tires)
Posi-Trac 4X4 Posi-Lok PSL920 - 4x4 Posi-Lok for Lifted 87-95 Jeep® Wrangler YJ & 84-91 Cherokee XJ, MJ - Quadratec
Rear Axle -
4.88 gear set
WARN Floating Rear Axle Conversion with upgraded axle shafts
gr33ng0bl1n is offline
post #2 of 9 Old 07-02-2010, 09:29 AM
LJameson
Well, it's really not geared correctly for 35's. But other then that it sounds good. Any pics?
1990 YJ
LJameson is offline
post #3 of 9 Old 07-02-2010, 09:50 AM
93iroZJ
what's wrong with 4.88 for 35" tires?????
93iroZJ is offline
post #4 of 9 Old 07-02-2010, 09:56 AM
Burns95
4.88's are the tallest gears that the Dana 30 housing will hold. This Jeep most likely has a 2.5l engine in which case, the 4.88's are as good as you will get without an axle swap.
Burns95 is offline
post #5 of 9 Old 07-03-2010, 08:41 AM
plumber1
Sounds like a lot of good stuff, the 4:88's may be a bit light but only you can tell. I know my Rio run's great with 4:88's but mine is on 33's. I would say drive it and then decide. You did not metion the price.
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #6 of 9 Old 10-17-2010, 09:27 PM
ilovemyyj
sounds like a lot of good stuff...i have a rio soa with 4:88 and was wondering how they'd do with 35s...let me know! how much anyways!?
ilovemyyj is offline
post #7 of 9 Old 10-18-2010, 04:53 AM
wendell
1987 YJ Wrangler
The 4:88's are fine, but I would swap down to 33" tires to get the most out of the 2.5.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #8 of 9 Old 10-18-2010, 12:29 PM
Mitchness
What worries me, since he didn't list an axle swap, is that he's running 35" tires on a locked D35. Even with the axle shaft upgrade that's begging for trouble. Other than that it sounds solid from what you've posted. A link to a CL ad or some pics would be nice though.
Mitchness is offline
post #9 of 9 Old 10-18-2010, 03:16 PM
jmonier
I have d30s locked and upgraded axles. 4.88s and 35s and havnt had a single problem yet. Terralow helps too. Not as low as id like it but bas low as I can go
jmonier is offline
1995 Rio Grande paint color cbman YJ Wrangler Technical Forum 6 09-26-2012 07:47 PM
1995 jeep wrangler rio grande door hinge removel mina678 YJ Wrangler Technical Forum 6 09-23-2008 12:34 PM
1995 Wrangler Rio Grande bucks under load Snailpower YJ Wrangler Technical Forum 8 04-19-2008 06:01 PM
1995 rio Grande Kyle- YJ Wrangler Technical Forum 11 05-24-2007 04:22 PM
1995 Jeep Rio Grande Vibrating above 50km but only in 4WD? apriloli YJ Wrangler Technical Forum 7 11-16-2006 06:21 AM
