Go down with the Jeep or get a new one? - Page 2 - JeepForum.com
post #16 of 18 Old 12-09-2011, 08:28 AM Thread Starter
Davecore555
So the transmission place called me today and said they couldn't find anything wrong lol, the tachometer isn't even jumping or stalling for them. They said that I could replace my u-joints if I wanted, but it wasn't critical. They also said they won't feel right trying to sell me anything because they just can't find a issue (Good sign).
So now I'm in a dilemma, they said they would drive it and mess around with it for a bit more. I'm not crazy it is jumping and all at stops and when I give it gas it feels like its building up and kicks out.
Should I just go ahead and replace my crankshaft position sensor?? Any help or advice
Davecore555 is offline
post #17 of 18 Old 12-09-2011, 09:22 AM
meatlord
meatlord's Avatar
Problem: auto trans malfunction.
Solution: install manual trans.
Problem solved.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" FOR SALE. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 03 Nissan SE-R 6 speed V spec. / 00 Suzuki DR650.
meatlord is offline
post #18 of 18 Old 12-09-2011, 09:58 AM
TrentYJ
yes, you should because that's the problem. This sounds exactly like what happened to me I took mine to a shop and there was "nothing wrong" but the sensor is failing not completely broken. replace the sensor and your problem will be gone.
TrentYJ is offline
dealership , pcm , torque converter , transmission
Jeep TJ Wrangler 1997 -2004 ,V-6 Conversion Package , Retaining the Stock Jeep 5?? Travisray91 TJ Wrangler Technical Forum 12 10-05-2011 12:50 PM
Pulled a Fellow Jeep out in wading Riverlong island..anyones jeep? LITJGuy Wrangler General Discussion 72 12-16-2010 09:31 AM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 09:22 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
