Go down with the Jeep or get a new one? - JeepForum.com
post #1 of 18 Old 12-06-2011, 06:22 PM Thread Starter
Davecore555
So after many issues I finally took the jeep into the dreaded Dealership service area. The tachometer jumps and stalls out at stops and my transmission builds up and kicks in randomly.
So this is what they reported:
1. Internal Failure in transmission torque converter-staying in lock up and stalling out engine at idle.
2. ATF fluid level approx. 1.5 Qts low on fluid and burnt
3. Replace Front U-joint, front yoke, 2 rear u joints.
4. Replace Both front wheel bearings worn and causing front tires to lean in.
5. Internal Failure in PCM
6. Replace Crank Sensor
Recommended:
Transmission overhaul w/ torque converter
Internal Seal Kit
ATF Fluid
New PCM and Crank Sensor
I need a lol.
They quoted me at $5,778.89 + Tax!!!!
What should I do, I'm going to call a few local places first. My buddy to is buys/sells at auctions for dealers said to get it fixed otherwise i couldn't give it away and I would be better down the road when i sell it myself to get a new Jeep.
99 TJ Auto
3.5 RE Lift
33 BF-G AT Tires
Dynomax Exhaust
High Performance Cat. Converter
Pacesetter Exhaust manifold
K&N Intake
KC slim fogs
Front/Back Black Warn Bumpers
Davecore555 is offline
post #2 of 18 Old 12-06-2011, 06:45 PM
freeskier93
If you can do all the stuff yourself you probably looking at 1000-1500 in parts, that's swapping in a junkyard transmission. Everything else is pretty simple stuff.
freeskier93 is offline
post #3 of 18 Old 12-06-2011, 06:56 PM
Imped
Imped's Avatar
Easy stuff. Do it yourself, save some money and learn a few things about your vehicle.
OlllllllO
IndyORV
Imped is online now
post #4 of 18 Old 12-06-2011, 07:02 PM
hndswthtshdws
In addition to the above I would like to mention that dealerships just love to replace U joints, wheel bearings, batteries, and brakes. A lot of times it isn't needed. Judge for yourself or have a knowledgeable buddy look at it. Don't trust someone's diagnosis when they stand to profit from it.
hndswthtshdws is offline
post #5 of 18 Old 12-06-2011, 07:07 PM
tjwrangler99
take it to a local shop... someone who has a decent reputation, and have them look at it. Dont tell him you took it to a dealer... See if they find the same issues. In the end, you may just need a new junkyard tranny... I can see a large chunk of what they quoted, being a nice new tranny... when you can get something used for much cheaper.
1999 TJ
BFG AT 31's | BDS 2" Lift | JKS Quick Disco's | Zone Rear Sway Links | TeraFlex 1/2" Drop+Washer | Warn M8000 | Viking 80' 3/8 Synthetic w/ Safety Thimble | Viking 350 Fairlead | MetalCloak AL Bumper | 99 Durango Steering Box | Uniden 520 CB w/ 3' FireStik | ebay header | Magnaflow Mid-Cat | Banks Cat-back | XJ Steering Linkage | Hella Black Magic (x4)
2011 Patriot FD1
tjwrangler99 is offline
post #6 of 18 Old 12-06-2011, 07:14 PM Thread Starter
Davecore555
Appreciating all the encouragement to keep the TJ, I've been getting getting the get the new 4dr JK. Which I personally don't like. Just too much life in my TJ still and all the time I've put into it.
I'm gonna call a local shop that was referred to me by the local jeep 4x4 place. They said to have him look at it. They said they consider him one of the most honest people/friend they know. They almost starting laughing at the dealer price when I told them. Unfortunately they don't work on auto trans.
If I get the parts myself any suggestions or rebuilt pcms etc... Also anything I should go ahead and upgrade if it comes down to rebuilding trans and replacing any of the other parts?
Thanks again everyone with the responses so far.
post #7 of 18 Old 12-06-2011, 08:43 PM
MsGTI
So true,took mine in last Wednesday to get the check engine light taken care of.
I knew it had to be one of the sensors so I was ready for that diagnosis.
They come back after an hour an half telling me 2 oxygen sensors (check engine light) and I needed: new battery (battery weak ),spark plugs and air filter needed so it will run right after the sensors are replaced.They wanted to charge me $300.00 for the extra stuff....I asked if the spark plugs were made of gold?The battery was $125.00 and I phased him out when mention the air filter's price.
I told them just the sensors to fix...than took it to Firestone to get a new battery and air filter for $120.00
"Everyone has a plan until they are punched in the face."~Mike Tyson
2006 Jeep Wrangler TJ Metallic Khaki
2009 VW GTI
MsGTI is offline
post #8 of 18 Old 12-06-2011, 10:01 PM
taphorn
I second the call for a trip to Firestone. My buddy with an F250 recently moved up to Washington took it in for an oil change. When he picked it up they said he had the wrong type tires on it for a 250. (he bought tires a year ago from firestone in salt lake). Anyway long story short they changed out his tires for the correct type for no charge. Pretty stand up company in my opinion.
taphorn is offline
post #9 of 18 Old 12-07-2011, 12:09 PM Thread Starter
Davecore555
Talked briefly to a transmission place today and they said they have seen the same issue and it was just a bad crankshaft sensor. But they said they would still check my transmission out for free. They said the $3,000 quote for the rebuild was way over. They said even with a whole new rebuild the most would be about $1200.
If the above is needed (yoke, pcm etc). Would it be smarter to just go with a SYE kit and are there any aftermarket PCMs that i should look at since I would have to spend the $$ anyway?
post #10 of 18 Old 12-07-2011, 12:10 PM
TrentYJ
Yep, its the sensor. I had the same problem. its a $30 fix. the dealerships always say everything is broken
TrentYJ is offline
post #11 of 18 Old 12-07-2011, 12:34 PM Thread Starter
Davecore555
I am hoping that is what it is.
Is replacing the Sensor easy? I'm no mechanic but I do my own tune ups and such. I just lack a lot of the necessary tools to complete some modifications.
Also if the PCM is bad does anyone know of any reputable sites to order. I found a few below but not sure:
They say they program to your VIN and mileage and tranny.
http://autocomputerexchange.net/1999...gler-1050.html
http://store.allcomputerresources.co...m19942006.html
post #12 of 18 Old 12-07-2011, 12:35 PM
freedommachine
2016 JK Wrangler
Its called stealership for a reason. Not long After I bought my TJ I called the dealership to quote me a price on dana 35 axle shafts. One was susposed to be 470 bucks and the other over 500. And thats just stock 35 shafts. I also ripped my rubber fill plug and needed a new one in a hurry, went to the stealership and paid like 10 bucks whenI could of got if offline for like 2 bucks. The stealership scares me!
In memory of JF member: mrknowitall666
Rest in peace brother- wounded warrior find your peace
freedommachine is offline
post #13 of 18 Old 12-07-2011, 12:52 PM
TrentYJ
The sensor is a clip and 2 bolts it'll take you 5 mins. Your PCM probably isn't bad i thought mine was too but it was just a few sensors. Pcm's are pretty expensive($200-300) so a junkyard is probably your best bet if that's actually what it is.
TrentYJ is offline
post #14 of 18 Old 12-07-2011, 12:55 PM
TrentYJ
^the sensor is on the bellhousing btw if its an "AX" tranny not sure on autos but probably the same.
TrentYJ is offline
post #15 of 18 Old 12-07-2011, 12:57 PM
bigred33
Oh boy. My 99 4banger was down for 7 months while I was trying to get it running from an ignition problem. Crank sensor is easy.
Aftermarket/reporgrammed PCM do NOT like mopar parts. I put one of those ACE ones in and it fried hot my alternator and 5 ignition coils (1 napa, 3 mopar). Couldn't figure it out until getting the old PCM back in and a jeep ignition coil and that was it. With that, I'm very leary of the PCM you can get online. Cheaper by far, but I'll never buy another one.
bigred33 is offline
dealership , pcm , torque converter , transmission
Jeep TJ Wrangler 1997 -2004 ,V-6 Conversion Package , Retaining the Stock Jeep 5?? Travisray91 TJ Wrangler Technical Forum 12 10-05-2011 01:50 PM
Pulled a Fellow Jeep out in wading Riverlong island..anyones jeep? LITJGuy Wrangler General Discussion 72 12-16-2010 10:31 AM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 10:26 AM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 10:22 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 05:46 PM
