Gears from 4x4 Groupbuy? - JeepForum.com
post #1 of 1 Old 06-21-2010, 12:50 PM Thread Starter
boozewell
I am having my ring and pinion gears changed in my 06 TJ. I currently have 3.73 gears and am going to 4.88. I ordered the Superior gear set from 4x4 Groupbuy for a D30 front and D44 rear which I have. I got the gears and the Ring and Pinions. The master install kit # is 35-2031 and 35-2033.
The ring and Pinion # are D30488TJ and D44489. this would be 4.88 gears in front and 4.89 in the rear? Did they send the correct gears for my TJ and will I need anything else for the install?
boozewell is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
