G2 D44 quality? - JeepForum.com
post #1 of 7 Old 02-03-2014, 03:51 AM Thread Starter
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
G2 D44 quality?
I have been running G2 D44 front and back... 4.56 with Detroit in the rear and arb it the front... About 30K miles. Did some fairly mild crawling last weekend nothing I would consider extreme... And it was tackled with slow and steady ...NOT crash and mash... After rolling my rig off the trailer I noticed that the pass side upper control arm bracket tore clean off! There was little to no penetration on the weld into the bracket... Solid on the deletion tube...
Anyone else had issues with G2 weld quality?
Ground the axel tube and bracket... Welded back into place and added a bead across the back factory was just on either side.
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion, SOLD!) 89' Int. Harvester Toter (get the TJ to and from)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process/million pieces)
j_bydesign is offline
post #2 of 7 Old 02-03-2014, 08:12 AM
222Doc
222Doc's Avatar
i think G-2 is made in china. though i seen a Currie axle tube pull right out of the carrier once. Same thing no penetration on about 80% of circular weld.
222Doc is offline
post #3 of 7 Old 02-03-2014, 02:41 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The G2 axles are made in California
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 7 Old 02-03-2014, 05:31 PM
tjcj
I've beat on my G2 and haven't had a weld fail.
Sent from my XT881freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #5 of 7 Old 02-03-2014, 08:19 PM
TimV
I've ripped off two passenger side upper brackets on stock axles. What control arms do you have? They are likely the problem.
It's not an addiction. It's a way of life.
TimV is offline
post #6 of 7 Old 02-04-2014, 03:22 AM Thread Starter
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
I am running Currie CAs uppers and lowers front and back... It was a quick fix but wonder if anyone else had similar issues
post #7 of 7 Old 02-05-2014, 09:58 AM Thread Starter
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
the axel tube had good penetration... the bracket... not so much? I believe they are built in CA...
