Fuel Pump replacement - JeepForum.com
post #1 of 11 Old 06-29-2010, 09:59 PM Thread Starter
jlm0516
My local Jeep dealership wants to charge $790 to replace a fuel pump in a 97 Jeep Wrangler 4 cyclinder. This seem kinda high, is it?
Thanks
~jlm
jlm0516 is offline
post #2 of 11 Old 06-29-2010, 10:02 PM
bs1946
Everything is high at a dealer. But don't worry, they'll give you a great trade-in deal right after you pay for the repairs.
bs1946 is offline
post #3 of 11 Old 06-30-2010, 04:05 AM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
It's not that difficult to drop the tank and replace the fuel pump. If you take your time it's a good afternoon project. For what the dealer is wanting to charge you, you could pay for a new pump AND a gas tank skid plate (Savvy, Rokmen, etc.) and still have a couple hundred dollars left over if you did it yourself. Maybe that thought will motivate you to make it a DIY project.
armyRN is offline
post #4 of 11 Old 06-30-2010, 05:38 AM Thread Starter
jlm0516
I didn't mention that the dealership first told me it was the crankshaft positioning sensor and it was going to cost $306 to replace. I figured I was $100 into already for them just to look at it and the sensor is $100 bucks plus going to get the Jeep and get it home, 300 bucks sounded ok. So now I have to hash it out with them about charging me for a repair that did nothing to repair my problem. My neighbor, isn't a mechanic but builds race cars as a hobby, said he would help me fix it. I might take him up on his offer.
Thanks,
~jlm
jlm0516 is offline
post #5 of 11 Old 06-30-2010, 09:55 AM Thread Starter
jlm0516
TJ is coming home. The dealership told me that when the fuel pump goes it's possible that it shorted out the crankshift position sensor. So, looks like I'll own that amount. The pump is $125 dollars, towing to get it home $75, Dealership is $306 and beer for me and my neighbor $20 = $526 vs $1096.
~jlm
jlm0516 is offline
post #6 of 11 Old 06-30-2010, 10:12 AM
Zen
If you're going to replace the pump, be sure whatever kit you get includes the filter as well. You don't want to have to go through this again if the filter needs to be replaced.
I replaced the entire fuel sending unit with one I got off rockauto.com for $160 and it was a simple remove/replace job. If you buy a pump/filter kit you will need to "rebuild" the fuel sending unit, taking it apart to replace the pump and filter then putting it back together. It's definately doable though.
Good luck.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #7 of 11 Old 06-30-2010, 11:52 AM Thread Starter
jlm0516
Good luck.
I am ignorant on the fuel filter for 2.5L 97 TJ. Is it the sock filter on the bottom of the pump?
Thanks,
~jlm
jlm0516 is offline
post #8 of 11 Old 06-30-2010, 01:02 PM
Zen
The fuel pump assembly drops into the fuel tank. It includes the pump, fuel filter/strainer, and fuel level sending unit. If you're replacing the pump, you should replace the filter. Or for a few bucks more you can replace the whole assembly.
-Stick, splash one!
Zen is offline
post #9 of 11 Old 06-30-2010, 03:58 PM Thread Starter
jlm0516
Here is the pump I bought.
The pump assembly is $170 more and no one has it in stock.
jlm0516 is offline
post #10 of 11 Old 06-30-2010, 08:17 PM
JeeperSC
If I were you id check places like Advance Auto or Auto Zone for a direct replacement. Also check some aftermarket companies online like Summitracing.com and it may be even cheaper. I replaced the fuel pump on my last car, an LS1 Z28, for under $150 and it was a high performance pump. I also did all the work myself which took about 30 minutes. The reason it didnt take very long is because I took a huge short cut. I pulled the carpet up, then cut a little trap door through the metal of the trunk exposing only the portion of the fuel tank where the pump is. After that it took me less then 10 minutes to swap a fuel pump. I did it the hard way the time before and it was a pretty tuff job I wouldnt want to do again. Hince why I sawed a hole through my car the second time. Dont regret it one bit.
2008 Wrangler Unlimited-X 4x4
Steel Blue Metallic
JeeperSC is offline
post #11 of 11 Old 07-01-2010, 07:08 AM
Zen
Next time check out www.rockauto.com. I thought the replacement Airtex assembly for your application was $170.
-Stick, splash one!
Zen is offline
Fuel Bypass Regulator vs. Replacement Fuel Pump gsmith795 YJ Wrangler Technical Forum 3 06-27-2009 05:35 PM
YJ Fuel Pump Replacement thegrizz51 YJ Wrangler Technical Forum 3 12-26-2008 07:42 AM
fuel pump replacement mose32 TJ Wrangler Technical Forum 1 11-03-2006 02:07 PM
Fuel Pump replacement mctrowell YJ Wrangler Technical Forum 4 09-01-2003 10:29 PM
Fuel Pump Replacement? Brendan YJ Wrangler Technical Forum 2 10-21-2001 07:09 PM
