Forever Black GARBAGE - JeepForum.com
post #1 of 31 Old 05-23-2008, 01:16 PM Thread Starter
Nonya
This garbage is a complete waste of time and money,It makes more of a mess than you had PLUS you can't paint over it!One car wash and its all speckled with white spots all over the flares.
Nonya is offline
post #2 of 31 Old 05-23-2008, 01:35 PM
krawler00
Bumper trim paint. Satin finish. Can't go wrong.
krawler00 is offline
post #3 of 31 Old 05-23-2008, 01:35 PM
Zoom By You
Zoom By You's Avatar
I also had bad results with with that stuff; it sucks! After cleaning and prepping well, I tried it on my stock flares (three to four coats) and it didn't last long and my Jeep is garaged. When filling my tank, I splashed a little gas on the flare and it took the finish completely off. FYI, it does come off with acetone, so you should be able to paint them. I ended-up just replacing the flares....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline
post #4 of 31 Old 05-23-2008, 02:24 PM Thread Starter
Nonya
I'm too allergic to paints to use them.I'm going to buy a replacement set.Its ashame though because these are like new but were just faded,now they look terrible.
Nonya is offline
post #5 of 31 Old 05-23-2008, 02:39 PM
BlueFlame
BlueFlame's Avatar
Your replacements will fade too if you don't treat them with something.
Forever Black if I remember right doesn't have any UV protection in it, so it's snake oil. Might as well use peanut butter.
Get some good vinyl and plastic cleaner, get em clean, then put some proper protectant on. 303 comes to mind as a good one.
BlueFlame is offline
post #6 of 31 Old 05-23-2008, 02:58 PM Thread Starter
Nonya
Made with new plastic polymers that resist fading better than OEM! http://cgi.ebay.com/ebaymotors/1997-...spagenameZWDVW
Nonya is offline
post #7 of 31 Old 05-23-2008, 08:40 PM
sportcoupe
Run a heat gun over your factory flares, they will quickly turn back to black and stay that way for a long time. It's safe to do on the Jeep too, the heat gun won't be near the paint long enough to do any damage.
sportcoupe is offline
post #8 of 31 Old 05-23-2008, 09:04 PM
BucketOKarma
Will that really work? Anyone able to second this method?
2000 2.5L 5spd 4.88, HP D30 w/OX, D35 open, 3" "FrAnKeNLiFt" with some stuff... LOOKING FOR Willys Edition TJ rear seat! to match the fronts.
BucketOKarma is offline
post #9 of 31 Old 05-23-2008, 09:10 PM
jake-cutter
I would also like to know if the heat gun works? I have tried the forever black crap, it is a waste of money. My Bushwacker fender flares need some reviving. I tried to use the warranty, and that was a no go.
jake-cutter is offline
post #10 of 31 Old 05-23-2008, 09:16 PM
Remington
I've tried this (the heat gun method), and it DOES work, but didn't yield an even color, and would have taken FOREVER...
I ended up getting a can of Krylon. For 4 bucks, an hour later they looked brand new..
Remington is offline
post #11 of 31 Old 05-23-2008, 09:21 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
we used to do it at work and yes it works...also a great way to fix small scratches in your flares is to heat them up quickly and lightly with a torch...they will smooth out quite a bit but be careful with the torch
Recoil is offline
post #12 of 31 Old 05-23-2008, 09:31 PM
1CleanTJ
1CleanTJ's Avatar
why not just take your flares off and have a family member, neighbor, random guy down the road take 5 minutes to spray them for you ? beats buying a new set.... I painted mine using duplicolor bed liner and it leaves a nice flat black textured finish, very easy to touch up when the flares rub against a tree or rock too
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #13 of 31 Old 05-23-2008, 09:37 PM
pilot-one
It works great and is much better than painting. You have to have a steady hand and move evenly and overlap passes much like painting.
It takes around 15 minutes or so for each flare.
Gravity Rat #149
But what do I know? I don't really even have a Jeep. I just make it up.
pilot-one is offline
post #14 of 31 Old 05-23-2008, 09:51 PM
slate210
It's not going to be fun taking off 11 year old fender flares. Spinning bolts never are. Just get them painted.
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member
- Some mods...
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline
post #15 of 31 Old 05-24-2008, 04:00 AM
TJamz
I did the krylon fusion paint thing two years and it's still holding up well. Looks like I did it yesterday and holds up to the pressure washer.
TJamz is offline
Forever Black on Flares Jeep25 Wrangler General Discussion 4 11-23-2008 03:38 PM
forever black???? Lil' Elvis TJ Wrangler Technical Forum 16 07-30-2008 12:33 AM
Apply Forever Black... 4x4Dogg TJ Wrangler Technical Forum 2 10-02-2006 09:52 PM
Flares and Forever Black Ole Yeller TJ Wrangler Technical Forum 25 01-12-2004 07:59 PM
forever black.... PaMuddin TJ Wrangler Technical Forum 2 01-28-2003 03:55 AM
