Fluid Film inside frame - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Fluid Film inside frame
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Alloy usa heavy duty ball joint kitsWe have FLASHLIGHTS! Great for your Emergency bag!
Unread 01-23-2014, 11:51 AM   #1
Ferrachi
I'm a fan of this product and just wanted to share how I have been using it on my Jeep for the past two years now. I picked up a gallon of it originally along with a cheap spray gun from Northern Tool and proceeded to coat the underside of my Jeep. At the time I did not have a way to get the product inside my frame in a even manner. I did a lot of research and found to equip myself with the necessary hardware of flexible hose and nozzles was cost prohibitive for my air gun.
I ran across a company that offered a plastic hose kit with 360deg brass spray nozzle for 25 bucks from TP Tools and equipment(TRE-4471). Coupled with fluid film in aerosol can for a fraction of the cost. Took 3 cans at 9$ each to coat the inside of both frame rails. Fluid film never hardens so I don't even bother cleaning the air gun or tips, no need to.
Fluid Film is more of a maintence product that will need to be applied once a year. Rust free in MN.
Ferrachi is offline   Reply With Quote Quick reply to this message
Unread 01-23-2014, 11:54 AM   #2
bschurr
Great creativity on the frame use. I am a fan of Fluid Film and have been for a while - it is a must for anyone with a plow not only for rust/corrosion prevention but for the blade too so that snow wont compact onto the face!
2005 Wrangler - New to me Jan 2013
1997 Wrangler - RIP
2009 Infiniti G37 Convertible
2006 Harley Davidson V-Rod
bschurr is offline   Reply With Quote Quick reply to this message
Unread 01-23-2014, 01:00 PM   #3
Ferrachi
Thanks. I've also plugged the frames holes that are exposed next to the tires to stop them from filling up with crap in the first place. Also drilled a small hole behind the front tires on the bottom of the frame so they can drain. Other then having the frame galvanized, I think I've covered all the bases to keep frame rust at bay, I hope
Just want to share what I have done on the cheap so others can keep their frames solid as well.
Unread 01-23-2014, 05:07 PM   #4
auburnhunter
I have been meaning to do this as well to my LJ. Thankfully I don't live in the rustbelt, but I plan on keeping this thing forever. I also drilled two 1/2" holes in the underside of the frame in front of the rear tires. One thing I recommend when drilling the holes is to chamfer the hole from the inside of the frame. I used a die grinder with a stone that fit through the hole.
I wish someone made rubber plugs for the holes in the side of the frame and the top of the shock towers.
"The problem with quotes on the internet is that you never know if they are real or not" - Abraham Lincoln
auburnhunter is offline   Reply With Quote Quick reply to this message
