#1 | |
Driver's Side Water...hardtop?
i hate to bring it back up,but i'm to the point i will sell my jeep if i can't fix this!i can't even park it outside in the rain,it leaks so bad just over the driver side floor.bad.i see it dripping off the bottom of the dash but can't tell where it starts.LAST YEAR THE THING NEVER LEAKED...i don't get it.it's about embarassing.anybody know where to start?my rubber seems fine,but who knows.
So, is there any tread left on the tires? Or at this point would it be like throwing a hot dog down a hallway? |
#2 |
Sell your Jeep over a little water leak? Really man??
![]() It could be a few different things. -Your cowl seal could be leaking -Your vent tube (under hood) could be clogged or not working correctly *To test these take your hose and spray water on teh cowl seal. If the Jeep leaks water afterwards, your seal needs replaced or modified. *If you spray water in the intake for the vent system and get water, then it's not working properly. (clogged or other)
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
#3 |
i know...i'm not about to sell it...but who needs the jeep smelling like a wet rug?..i'll try those things.i've read about the cowl vent getting mud in it.is it easy to check?
#4 |
The top may simply need to be adjusted.. Did all 6 bolts go in with no trouble when u last put it on?
'01 TJ, Waggy 44 front, D44 rear, Both locked and loaded, Savvy Armor, SuperWinch LP8500, MetalCloak bumper, and a heavy foot. |
#5 |
yep.everything went together fine.idk.it just pours inside.
#6 |
If if water is comming from behind the dash it's gotta be the cowl seal.
Mine did that after a weekend with the windshield down. I insulated it a little better and it seals up water tight again.
#7 |
somebody tell me how to get to it then...
#8 |
Come on man, that has been Jeep tradition for years, I've never heard of a Jeep that was ever made that didn't leak somewhere even the new ones, Jeeps aren't Cadillacs. My Jeep leaks on the floorboard too and I think it is a cowl seal or the vent tube, either way I'm sure that is what is wrong with yours. Like I said Jeeps are Jeeps they won't ever be completely water tight. Just my $0.02 worth.
#9 |
i believe i found it.it's not the cowl,but the rubber the door hits.it's the piece at the bottom of the windsheild.anybody know if i can buy a replacement?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
