Dremel near the fuel lines - JeepForum.com
post #1 of 5 Old 05-18-2013, 05:25 PM Thread Starter
disarm6565
I want to fix my e-brake cable, which involves slicing it in two. If I use a dremel on it, what precautions do I need to take not to blow myself up with sparks so close to the fuel lines?
1993 4.0 AX-15
disarm6565 is offline
post #2 of 5 Old 05-18-2013, 07:05 PM
larjeep
If u r worried stick a piece of tin or so next to it while u r cutting
DO IT ALL, AND THAN SOME!
larjeep is offline
post #3 of 5 Old 05-18-2013, 07:31 PM
JBTJ
Using a Dremel to cut thru a brake cable will not cause enough heat to the fuel line causing an explosion.
JBTJ is offline
post #4 of 5 Old 05-18-2013, 07:39 PM Thread Starter
disarm6565
even with possible fuel vent hose leaks and sparks?
1993 4.0 AX-15
post #5 of 5 Old 05-19-2013, 06:43 AM
jay-h
Always take gasoline seriously.
However, hopefully you don't have heavy enough fumes to be spark sensitive or else that's an even more critical thing to fix (imagine driving over someone's tossed out cigarette butt). If you have any actual wetness, do something about that. if it's dry there should be no problem.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
