Does 'PB Blaster' and other penetrants REALLY work or....?
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
...is it just psychological?
You often read how people "spray with PB for several days" before undertaking a knuckle-busting repair. My question is if anyone can state with no doubt that there was a significant difference if they had not used PB? I have noticed a big difference using a MAPP gas torch but I am not really too sure if PB or any other penetrants actually made a difference...except making me more determined. What are your thoughts?
This is where Jeeps first caught my attention. http://www.youtube.com/watch?v=5X_nnGuOdKA Old man: "He said there's a storm coming" Sarah Conner: "I know" |
#2 |
Got my eye on you.....
I have yet to encounter something that PB blaster did not break free minus a heavily seized spring bolt. Everything else has I have always had success with using PB.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#3 |
yes it works
#4 |
PB Blaster=ok. A 50/50 mix of acetone & ATF=Best Ever! Here's the cold, hard facts from the April/May 2007 edition of Machinist's Workshop. They did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better.
Penetrating oil . Average load .. Price per fluid ounce None ................. 516 pounds . WD-40 .............. 238 pounds .. $0.25 PB Blaster ......... 214 pounds .. $0.35 Liquid Wrench ... 127 pounds .. $0.21 Kano Kroil ........ 106 pounds .. $0.75 ATF-Acetone mix.. 53 pounds .. $0.10 |
#5 | |
Just watch.... don't want to be putting acetone on any torx bolts outside the body. Underneath, OK. ![]() PB works. I tried to loosen the nut where the track bar connects to the frame side. No luck. So I drove back to school, and everyday before class as the motor was warming up, I'd give it a healthy dose of PB blaster. My next attempt a few days later to remove the nut..... success! |
#6 |
I will indeed have to try the Acetone/ATF mix.
I will pick up a can of acetone from HomeDep today. My goodness, the price and the stats make it no-brainer. thanks for the tip. I've seen someone mention it here but now I see the hardcore data.
#7 |
I read the actual article and switched to the 50/50 the next day...has made restoring my old Plymouth far easier. Wish I had known of it years ago.
#8 |
Yes it works well, especially if you can spray on top of the bolt so it can gravity feed down. The acetone is the penetrant. Its not the best penetrant but its the safest. For really stubborn crap you can use a better solvent. Just be careful and read the directions of any other solvents you try
Your limited slip differential sucks. |
#9 |
I'll tell you what really works a four foot pole. But seriously thats pretty sweet I've always wondered the same thing. It certainly seems like PB helps but I never now if thats because I have already started to work the bolt loose before I try PB.
#10 |
on my winch where the switch that lets the winchline IN or OUT was stuck in the IN postition. i tried using WD40 and it wouldnt budge. went out and bought some PB blaster, well the switch was wrorking the same day, and is still working 1 week later
www.youtube.com/kgries http://photobucket.com/kgries in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash.. |
#11 |
PB blaster works great! I live by it when doing wrenching on old bolts.
NRA Life member Square Headlights group member #222 Armed Forces Jeeps group member #65 United States Air Force group member #12 Guns and Jeeps group member #10 Ron Paul Jeepers group member #7 |
#12 |
but the stiff stinks. i sprayed my seat sliders since they were sticking and my jeep still smells 2 weeks later
#13 |
Toss all your cans of PB Blaster away....It's "ok" for rust ....But,
Purchase CRC "FREEZE OFF" that $#@! ROCKS!!! It's gets deep into the grooves and will let free pretty much anything thats rusted. CRC Freeze-Off Super Penetrant loosens rusted and corroded nuts, bolts, couplings, fittings, hinges, locks & frozen components. Freeze-Off is a unique formula that immediately drops the temperature of the area in direct contact with the spray. The freezing effect cracks rusted surfaces, allowing Freeze-Off to reach deeper & work more effectively than other penetrants. Lubricating film prevents corrosion and displaces water. This is a low VOC formula. I will assure you that you will be tossing out your PB Blasters goodbye forever! You'll be using the "FREEZE OFF" like it's a Rust away god. This stuff is Awesome! +A & 5 Stars for this product! BUY IT NOW!!! IT ROCKS!!!
I'm Michael, Founder of: "Jeeps Gone Wild™" www.JeepsGoneWild.org <>< |
#14 |
You work for CRC or something? lol
I love PB Blaster, been using it on my Z for a while and on a 19 year old car it works wonders. |
#15 |
actually hes right about the crc, I have had a few bolts that wouldnt budge with pb, but the crc took em right off
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
