Quantcast did i get a deal or what!?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > did i get a deal or what!?!
Old 03-12-2010, 02:38 AM   #1
jakers226
just picked up a ford 9 inch housing for $200 but here's the kicker(s) it already has all the brecketry for a soa YJ, has D60 front spindles welded on, disc brake brackets, 31/30 double spline chromo shafts. all it needs is a 3rd member, brakes and drive slugs.
i will be getting currie's high pinion 3rd member with a detroit and 4.86 gears.
[]lllll[] '92 YJ, 2.5, AX5, 30x9.5 cooper discoverers
Muddy Buddys Member
jakers226 is offline   Reply With Quote
Old 03-12-2010, 02:54 AM   #2
provinT13
pics or lies
2 Hands Working Do More Than 1000 Hands Praying
94 YJ Build
99 TJ Build
provinT13 is offline   Reply With Quote
Old 03-12-2010, 05:00 AM   #3
JeeperFound
Pics or I call hog wash!
My daughter just asked me if I can buy a motorcycle when I'm done with my Jeep!!
JeeperFound is offline   Reply With Quote
Old 03-12-2010, 09:18 PM   #4
TSEJEEPERS
Pics.
Not trying to screw up your plan but you may look into a Hi9 before the Currie unit.
The Currie Units use a 8.8 ring and pinion. I believe 4.56 is as low as you can go.
The Hi9 uses 9" ring and pinion. Not only stronger but pretty much endless gear ratios.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 03-13-2010, 01:00 AM   #5
asknight
DW victim # 7,471,643
asknight's Avatar
Originally Posted by TSEJEEPERS View Post
Pics.
Hogwash. 8.8 can go down to 6.14 unless there is some kind of limitation in the Currie Unit making it not compatible with all 8.8 gears.
YG F8.8-614 - CROWN,PINION,RING,RING PINION,YUKON,YUKON GEAR,CROWN PINION,CROWN WHEEL,FORD,DIFFERENTIAL,FORD 8.8,MUSTANG,GEAR,YUKON AXLE - High performance Yukon Ring & Pinion gear set for Ford 8.8 in a 6.14 ratio. Yukon exclusively uses 8620 steel i
Currie has 5.14 available 3rd members on their site.
http://www.currieenterprises.com/cestore/3rdmember.aspx
asknight is offline   Reply With Quote
Old 03-13-2010, 08:41 AM   #6
TSEJEEPERS
Sorry just looked at Curries site. They list 5.29 as their lowest.
I would still go with the Hi9.
If I remeber right Currie states 35" tires is as big as you should go with their high pinion 9.
I am running 36" Iroks and have not had a problem with the Currie unit.
Old 03-13-2010, 08:49 AM   #7
jeepinmichguy_
Resident *** Hole
jeepinmichguy_'s Avatar
iroks are also a very light tire. i would think your 9 would hold up to bigger than 35's though.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Special thanks to the following vendors for supporting the TJ of the Month contest:
jeepinmichguy_ is offline   Reply With Quote
Old 03-13-2010, 10:00 AM   #8
DBLJ
DBLJ's Avatar
Those look like the LP thirds.
DBLJ is offline   Reply With Quote
Glock Forum
