Dana 35 with 31's - JeepForum.com
post #1 of 15 Old 06-28-2013, 06:44 PM Thread Starter
Mayberry1981
Dana 35 with 31's
I just bought a 97 TJ Sahara with the Dana 35 rear axle. If I only want to run 31's am I still ok? My experience is limited to the indestructible 85 CJ7
Mayberry1981 is offline
post #2 of 15 Old 06-28-2013, 08:11 PM
Xpress
It will be just fine.
All about that unibody life.
Xpress is offline
post #3 of 15 Old 06-28-2013, 08:15 PM Thread Starter
Mayberry1981
Thanks amigo. Still learning about the new fangled rigs
post #4 of 15 Old 06-28-2013, 11:06 PM
Moezer
2015 JK Wrangler
im running 33 swamppers with mine d 35 with limited slip
Moezer is offline
post #5 of 15 Old 06-29-2013, 05:00 AM
tankinyj
I ran a turdy-5 with 31s on my YJ for about 2 years, no problems.
2012 JK, 44s locked on 4.56s, 4:1, 3" on clayton arms, 37" PBRs
Crush Orange Jeep Member #55
tankinyj is offline
post #6 of 15 Old 06-30-2013, 10:36 AM
acat
If you start bouncing off rocks, throwing the clutch, etc. You will damage the 35 on small tires. Just be aware of it and wheel with a little caution and it will probably treat you well.
acat is offline
post #7 of 15 Old 06-30-2013, 08:35 PM
jarrodblake
1978 CJ10
I once ran a dana 35 on 35s with 4.88 gears and a locker lol that said I babied it and never had a problem.
jarrodblake is offline
post #8 of 15 Old 06-30-2013, 08:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sometimes 31's are too much on the street.
Luck Favours The Prepared
Anticanman is offline
post #9 of 15 Old 07-01-2013, 11:00 AM
wendell
1987 YJ Wrangler
The 35 will hold up fine with 31's for normal trail use and even some extreme stuff, however, you don't want a constant diet of the big rocks. They can even damage the 8.8. If you want to make your 35 a little tougher, throw in a set of 30 spline axles with a matching Detroit tru-trac, this will get you trough some pretty rough country when needed. MY 35 has held up well over the years with 31's.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #10 of 15 Old 07-01-2013, 02:51 PM Thread Starter
Mayberry1981
Thanks y'all. I Plan to run 31s for 2 or 3 years then upgrading to 33s. Ain't really got any rocks here in East Texas and I really don't plan on hitting the hard mud. Just mainly some trails. I'll just have to yake some care.
post #11 of 15 Old 07-02-2013, 09:32 PM
1998tjsport
31s are fine, ran them on my first tj with a d35 for its whole life no problems.....
WTB INCA GOLD HALF DOORS PM ME
Current-
2003 INCA GOLD TJ Rubicon 5 speed 3inch Currie/Savvy Lift, JKS Discos, 305 KM2s
Build Thread
Past-
1994 Grand Cherokee 5 SPEED 3inch lift, tj bumper, 31x10.5s, wheel spacers, rhino liner, ect.....
1998 TJ Sport 5 Speed 31x10.5s, completely murdered out, and a short throw haha (miss that jeep)
1999 TJ SE 5 Speed (ls swap that became a part-out due to excess frame rot)
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
1998tjsport is offline
post #12 of 15 Old 07-06-2013, 08:51 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
I had 31s on D35 from 1998-march 2013. Now on 33s. DD and weekend warrior for me, never a problem.
May TJ of the Month 2015
TexasTJ is offline
post #13 of 15 Old 07-07-2013, 01:09 PM Thread Starter
Mayberry1981
I'm still on 235/75s and I noticed my rearend leaking. Pulling the diff cover I noticed a dent by a diff cover bolt in just the right spot where it won't come out. After pulling all the other diff bolts I was finally able get it off. Lo and behold there is a bolt with the head sheared off in the bottom of my housing. The crazy thing is there wasn't any noises from the rear end. Have to get some pics of it here tomorrow
post #14 of 15 Old 07-08-2013, 12:21 AM
Specter1911
I DD mine with the D35 and 33's. With playing mostly in snow and mud.
Specter1911 is offline
post #15 of 15 Old 07-16-2013, 03:56 AM Thread Starter
Mayberry1981
Apparently it was my ring gear bolts that decided to start biting the dust. Done lost three. Guess I ain't hitting the trails this weekend. Unless I could hit the hardware store for some grade 8 bolts? Was going to order new bolts from Quadratec but if I can get replacements sooner....
