Cranking Problem with 2008 RHD Postal Jeep - JeepForum.com
post #1 of 3 Old 08-04-2010, 09:11 PM Thread Starter
bdobbi
We have intermittent cranking problem with the Jeep. Most of time, it cranks fine. But, periodically it clicks like a dead battery when you turn the key. Try several times and it won't crank. Then, it may crank on the next turn. Use to could tap the battery connection and it might crank or take the connection loose and then reconnect and it would crank. Neither works consistently, though. This week, had it towed to dealer and then it cranked every time for them and they said they couldn't diagnose anything wrong. There is another postal carrier in the Post Office that has the same Jeep and it is doing the same thing. Dealer says nothing is showing on their machines and it cranks every time for them. Anybody had this problem?
bdobbi is offline
post #2 of 3 Old 08-04-2010, 10:11 PM
CrzyMtnMan
Sounds like the starter. Probably a dead spot in it.
CrzyMtnMan is offline
post #3 of 3 Old 08-05-2010, 09:30 AM
PhulesAu
Technician syndrome.... Take a picture of the mechanic at dealership and tape it to the firewall.
PhulesAu is offline
battery , crank , starter
Problem with 2008 Wrangler pastime Wrangler General Discussion 6 05-10-2010 07:55 AM
1991 Jeep YJ - Only Cranking, but not starting. wonderbrar YJ Wrangler Technical Forum 10 11-17-2008 03:24 PM
2008 x convertible problem bernietech JK Wrangler Technical Forum 4 10-06-2008 02:51 AM
is a 550 cranking amp battery from a car ok to use in my jeep? chaznad TJ Wrangler Technical Forum 4 08-27-2005 10:43 AM
Converting Postal Jeep to 4X4?? jeeptoplesstx TJ Wrangler Technical Forum 7 05-21-2004 02:20 PM
