Cost of Body Lift Installation - JeepForum.com
post #1 of 17 Old 07-08-2013, 01:05 PM Thread Starter
RedRocks
Does anyone have an estimate on what it might cost me to have a professional mechanic to install a 3" body lift on my TJ?
RedRocks is offline
post #2 of 17 Old 07-08-2013, 01:09 PM
JBTJ
No way would I advise for a 3" BL. 1.25BL max would be the best.
JBTJ is online now
post #3 of 17 Old 07-08-2013, 01:14 PM
biffgnar
biffgnar's Avatar
They should be able to do it in an hour, but will probably charge you more. Anything over two is robbery IMO.
biffgnar is offline
post #4 of 17 Old 07-08-2013, 05:37 PM
larjeep
Book time on body lift is 3-4 hours. And they will charge you ny the book prob.
DO IT ALL, AND THAN SOME!
larjeep is offline
post #5 of 17 Old 07-08-2013, 06:21 PM
MountainMan864
Shops around here charge about $500 for a body lift install.
MountainMan864 is offline
post #6 of 17 Old 07-09-2013, 06:58 PM
MrDubbe
Ouch that sounds like sh***y deal. Body lifts are beginner lvl easy, the hardest part would be relocating the fan shroud.
Make America great again!
MrDubbe is offline
post #7 of 17 Old 07-09-2013, 08:42 PM
jjvw
jjvw's Avatar
3" = 3X more difficult. That's why the OP should stick with a 1" BL.
jjvw is offline
post #8 of 17 Old 07-09-2013, 09:05 PM
legato
op, you might as well just buy an actual lift; around here they charge $350 for installation -assuming its the same in you area.
i think you should look around your area for a 4x4 shop.
If I were an ARB in a Dana 35, I would kill myself too.
legato is offline
post #9 of 17 Old 07-10-2013, 01:04 PM
Sparrows
Omg only a 3" BL!?
Think big son. 6" is where its at.
Dammit I'm in a sarcastic mood today.
Not only should you never, ever, EVER deface your jeep with an abhorrent BL like that, you better not make it worse by paying to have it royally messed up!
Get a nice 1"BL from daystar, do a bit of reading, and put it on yourself. Then get a 1.5-2" BB and also put that on yourself. It will cost you less than having a shop install the 3" BL and your jeep will thank you.
Cheers
June '13 YJOTM
Sparrows is offline
post #10 of 17 Old 07-10-2013, 01:14 PM
Ken Cooke
I went to Tijuana, Mexico and had a 1" Daystar body mount/lift and 1" Currie Motor Mount Lift installed for under $100 by a great mechanic.
Luis tackling the Motor Mount Lift installation
Question: Do you really want a 3" body lift on your Jeep???
Ken Cooke is offline
post #11 of 17 Old 07-10-2013, 06:17 PM Thread Starter
RedRocks
I dont think 1" would give me enough clearance for the 35's I want to put on. Thats why I thought putting on a 3" inch lift would be the cheapest option for getting enough clearance.
RedRocks is offline
post #12 of 17 Old 07-10-2013, 07:33 PM
jjvw
jjvw's Avatar
For the sake of helpful questioning, wouldn't a 3" BL also require modifications to the shifter and t-case levers, the gas tank filler neck, fan shroud and other things I'm unaware of (steering linkage, maybe?)? All that money and time could be put into a functional suspension lift.
2003 Rubicon
jjvw is offline
post #13 of 17 Old 07-10-2013, 07:48 PM
Sparrows
Why are you going with 35s? There is a he'll of a lot more required to run 35s than just clearance....you have a lot more reading and research to do. Axles, gears, brakes, steering, all have to be loomed into.
Cheers
June '13 YJOTM
Sparrows is offline
post #14 of 17 Old 07-11-2013, 09:28 AM
biffgnar
biffgnar's Avatar
If you want to run 35s read this: http://www.jeepforum.com/forum/f9/i-...-my-tj-751873/. As stated, thinking you can slap a 3" BL on and be good to go isn't even close.
biffgnar is offline
post #15 of 17 Old 07-11-2013, 10:25 AM
Imped
Imped's Avatar
You're clueless....and that's not an insult, that's the truth. Please do some research and learn a few things.
OlllllllO
IndyORV
Imped is offline
