Considering an LJ - Page 3 - JeepForum.com
post #31 of 47 Old 07-05-2013, 09:40 AM
M2LJ
Originally Posted by esad_b View Post
Seeing this thread I stumbled on a LJ this evening on my local classifieds..
06 LJ Rubi, black on black, manual. 125k KMs (not sure what that is in miles) they want just under 14K for it.
Very tempting..
125K kilometers is a tad over 78K miles...
M2LJ is offline
post #32 of 47 Old 07-05-2013, 10:40 AM
esad_b
Yup, your right.
Went and looked at the jeep this am. pretty much stock, has hardtop and softop.
Seems in decent condition, also the softop stuff is all in a boot so looks like it might never have been taken out. In the glove compartment the stuff is also all sealed and wrapped, all the straps etc..
I might go test drive this thing on Monday as I was busy today.
Overall looks like a decent jeep, frame appears to just have surface rust.
Now this year would have the OPDA issue I know off. What exactly else should I look for on these? I pressed the locker button and didn't see the light flick on, but I was stationary.
Sent from the I-device using an APP
esad_b is offline
post #33 of 47 Old 07-05-2013, 10:43 AM
mukluk
Come over to the Dark Side, we have cookies
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #34 of 47 Old 07-05-2013, 10:46 AM
esad_b
Don't tempt me! I've always wanted a black one with it being a rubi and LJ is really tempting me.
I asked the guy to run some numbers to see what kind of trade in I would see on my jeep. But I know that would not be a chance id rather private sell my rig.
esad_b is offline
post #35 of 47 Old 07-05-2013, 10:51 AM
mukluk
Main thing to look for is rust, the frames have a tendency to rust from the inside out and it can get a bit pricey to repair. Other than that it's pretty much the standard used car list -- watch out for leaks, weird noises, worn parts, handling problems, evidence of collision damage/repair, etc.
As for the lockers, unless modified they will only engage when the transfer case is in 4LO and you are stopped/moving less than 10mph. Pushing the button once will turn on the rear, pushing again will toggle the front ON/OFF, pulling the switch back up will turn them both OFF.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #36 of 47 Old 07-05-2013, 11:40 AM
esad_b
Yea thanks ill have to check it out, hope to test drive it Monday.
I know it's got rust on the door handles- typical jeep rust spot. Fenders are clean.
esad_b is offline
post #37 of 47 Old 07-05-2013, 12:57 PM
MATT99TJ
I can speak on the car seat issue. 06 LJ stock height. I am 5'10" 175# reasonably fit.
I purchased my LJ Rubi the week before my son was born. I've had him in there rear facing, with a car seat that snaps into a base that is mounted via the LATCH points. I've never had a problem getting him in and out with that setup. It was far enough back for my wife to ride comfortably up front. A permenant rear facing seat would be more difficult. I honestly wouldn't even try that.
If I was in your shoes, I would either get a seat that snaps in and out of the base or wait until the little one is ready for forward facing. My daughter was 4 when I got the LJ and did require assistance buckling up. She only uses a booster. She is now 6 and buckles herself in. She climbs in and out of the jeep with little assistance from me.
My advice is look at her weight and height, try to figure how much longer she will be rear facing, then decide if you are willing to buy a new seat (assuming you don't already have that type of seat, we did so it was easy) that you might not use very long or if you would rather wait till she is forward facing.
Good luck hunting for your LJ. I wasn't looking when I bought mine, just ran into a guy that was trying to sell it, and I couldn't pass up the deal.
MATT99TJ is offline
post #38 of 47 Old 07-05-2013, 01:41 PM
joe108
I wish I could have held out for a LJ, the extra room would be great.
Just thinking here... is there ANY way you can hold out/save for a JK 4dr? the rear doors would make it way more practical as a second vehicle and lots easier for people of all sizes to get in and out of.
If you could find yourself a lower trim JK and upgrade in time might be an option, my next one will probably be a JK, but that's down the road.
joe108 is offline
post #39 of 47 Old 07-05-2013, 02:51 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Agreed as long as it is a 2012 or later.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #40 of 47 Old 07-08-2013, 03:05 PM
esad_b
So I test drove it.. Does feel smoother than my TJ due to the wheelbase and the 6cyl is
The seating in the thing is deff odd/strange, I was right sunk in. But that's nothing really and a few washers can't fix.
But the thing had quite a few issues that my quick glance missed on Friday..
1) severe rust on passenger floor, the carpet was wet and we've had nothing but 30+ Celsius weather this last week. It was quite bad.
2) gear 1, 2 and 3 I could hear some sort of POP as I shifted into it. The clutch worked fine but the shifter was just weird and very stiff.
3)The 4wd shifter was also messed, pulling it back into 4hi it wouldn't activate at the stop mark when you pull it all the way back you have to push it some forward in order to activate even then it seemed fidgety. I couldn't even get it into 4low to test lockers as the shifter wouldnt go to the side at all, I used my whole body to push it over to pull it back and just no go at all..
4) some odd clunks/taps on bumps and braking, believe the trans mount is gone. Seemed like the seal behind the oil pan and trans was leaking too. Did not sound very good. Underneath was just too rusted for my liking.
This made my 97 look like new vehicle.
esad_b is offline
post #41 of 47 Old 07-08-2013, 03:18 PM Thread Starter
goofiefoot
I think that's going to have to be the plan. My wife looks at me buying a LJ as a stop-gap before I move to a JK (she may be right - she's a pretty smart girl), so I'll just hold out for a while longer. Thanks for the info!
goofiefoot is offline
post #42 of 47 Old 07-08-2013, 03:34 PM
cjheap
It all depends on what you want to use it for.
Do you want a 4 door minivan (like the wife wants) or do you want a Jeep with a little more room ?
I have looked at the Jk since they came out and even rented a 4 door 2012 when my wifes Outback was in the body shop. They are gutless turds.
cjheap is offline
post #43 of 47 Old 07-11-2013, 09:12 AM
aikenjeep
Keep searching. I just purchased an '05 LJ last month. I searched and found one in Florida. It's a 2 owner, 35k miles, 4.0, 6 speed, full color matched Rhino Lined interior front to back, soft and hard top, brand new American Racing rims and Michelin LTX tires, aftermarket front and rear bumpers with swing out tire carrier, nice sound system and a clean carfax. I paid $15,500 for it.
We have already put 2k miles on it, and we just pulled a pop up camper (1800 lbs) from SC to IN and back with no issues. Remember the LJ has a 3500 lb. tow rating compared to a standard TJ's 1000 lb.
It runs flawlessly and we have been very happy with our purchase. Oh, and our 7 year old daughter rode the entire trip in the back seat.
Hope you have good luck in your search.
aikenjeep is offline
post #44 of 47 Old 07-11-2013, 09:22 AM
JohnyPro
CT Jeep Member #19
Yellow Jeep Member # 104
LJ Owners Group Member # 140
PMA: Positive Mental Attitude
- It's what reminds you as you're stuck in the mud, that at least you're stuck in the mud and not in an office cubicle!
God is great, Beer is good, an' people are crazy!
DEVILDG03
This is my Jeep. There are many like it, but this one is mine.
JohnyPro is offline
post #45 of 47 Old 07-11-2013, 10:25 AM
blackjeep05
Yea I would hold out for an LJ if you really want one. The JK is nothing like a true Jeep and every one I have rode in rattles because of the cheap plastic pilars around the doors. Plus a V6 in a Jeep is just wrong.
Soccer six in the mix.
blackjeep05 is offline
