cheap smaller lift ideas needed - JeepForum.com
post #1 of 17 Old 11-27-2008, 10:48 PM Thread Starter
tommyramone55
Recently bought an 04 jeep wrangler....I need some quick ideas on how to put a couple inches on my baby.
So uh...should i do shackles? or spacers? anything!!!
thanks
tommyramone55 is offline
post #2 of 17 Old 11-27-2008, 10:50 PM
Luckyduck
You need to learn more about your jeep first. Why are you trying to lift it? These jeeps have coil springs so spacers are the cheapest way. shackles are impossible
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #3 of 17 Old 11-27-2008, 11:06 PM Thread Starter
tommyramone55
shackles on the back are impossible when i look under i see where they would be possible.
and many other people say that they have them.....
post #4 of 17 Old 11-27-2008, 11:08 PM
provinT13
^^ you can only use shackles on a leaf spring vehicle, you have coil springs. Coil spacers, 1" body lift would get you a little
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #5 of 17 Old 11-28-2008, 12:46 PM
bigsquat
you guys are to young to remember, but way back there use to be a spacer that you would screw into the side of the spring to raise your car up a little. the were a little bigger than a golf ball if i remember right.
it was threaded like a screw and was turned into the coil with a 1/2 drive rachet. can you imagine how many broken windows with lose things flying out on the freeway!
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #6 of 17 Old 11-28-2008, 12:53 PM
Krautzy
thanks
Budget coil spacers are fairly cheap. You can usually get a couple of inches there. You could also get an inch or two from a body lift. Hockey pucks under your seats will make you feel a little taller too...
Krautzy is offline
post #7 of 17 Old 11-28-2008, 12:59 PM
Krautzy
Shackles on a TJ
Dont get what you mean about when you look under and see they would be possible...? And the other people who tell you that you have them are mistaken. Coil-sprung suspensions have no shackles. Shackles are on the end of LEAF spring packs, and allow for deflection, etc..
Krautzy is offline
post #8 of 17 Old 11-28-2008, 01:02 PM
Krautzy
thanks
Hey, man, fill out your profile! And welcome aboard !
Krautzy is offline
post #9 of 17 Old 11-28-2008, 01:05 PM
Krautzy
Coil spacers
Yeah I remember those. Boo-hiss... They were okay so long as you werent actually driving the vehicle. Dont some states have laws against those things?
Krautzy is offline
post #10 of 17 Old 11-29-2008, 04:41 PM
nitrous_bob
oh no... i remember those, they never seemed right for ANYTHING
nitrous_bob is offline
post #11 of 17 Old 11-29-2008, 05:50 PM
Imped
Imped's Avatar
As previously mentioned, shackles are only for leaf-spring suspensions. You have coil springs. Also, it is stupid to lift the jeep just to lift it (in my opinion). Why do you want to lift it? Tire clearance? Just for the "cool" factor? That factor will disappear when you realize what lifting is actually for. If you have stock tires, you already have enough clearance and bump stop length. Why raise the center of gravity more than it needs to go? That's why you see trimmed fenders, tube fenders, highline, etc.....to create more room for larger tires without having to lift the vehicle. Ideally (to an extent), you want the biggest tire possible with the smallest amount of actual lift possible, while still having adequate up and down travel clearance. Do some research before you just spend money to spend money.
OlllllllO
IndyORV
Imped is offline
post #12 of 17 Old 11-30-2008, 09:54 AM
jay-h
I'm old enough to remember (59). What a great way to introduce high local stress into your coil springs. The incredible stupidity of people who wanted their cars to look 'set up' but didn't want to actually spend the money to do it correctly.
jay-h is offline
post #13 of 17 Old 12-02-2008, 11:25 AM Thread Starter
tommyramone55
Yeah sorry when I looked at what I thought were leaf springs it was in the dark.
And yea im taking up so i can play in the mud with bigger tires.....call me what you want, but I love to play.
Im new to jeeps so take it easy on me.
post #14 of 17 Old 12-02-2008, 12:21 PM
Little Green
1991 FSJ Wagoneer
To expand on imped4now's advice, unless you are rock crawling where high departure and break angles are critical the ideal set up is more tire, less lift. It serves a couple of purposes-lowers your center of gravity which helps with not only fuel economy but with everyday driving such as sharp turns(think how low porsches are, interstate driving(you have a shorter brick vs a really tall brick on the road) which will help with wind resistance etc. I don't rock crawl but I, like you, love playing in the mud. Here, what you are looking for is a nice wide tire with lots of grip that will help get you through the thick stuff. If you can lift your Jeep and inch and get 32 or 33" tires then that's where I would spend my money as well as decent tow points, front and rear as well as a solid tow strap. just my .02$
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #15 of 17 Old 12-03-2008, 10:21 AM Thread Starter
tommyramone55
man. see i like how your nice about it haha.
and thanks for the advice sounds great man.
More Lift Needed or Smaller Tires pjleslie03 TJ Wrangler Technical Forum 13 10-21-2008 08:10 PM
Cheap Exhausts, any ideas? willhbauto TJ Wrangler Technical Forum 19 04-11-2008 06:17 PM
Ideas for good cheap mods parrot5254 YJ Wrangler Technical Forum 16 02-21-2007 08:52 PM
cheap snorkel ideas TJ_Firefighter TJ Wrangler Technical Forum 11 05-10-2006 10:23 AM
