Can the TJ Pull this? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Can the TJ Pull this?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 07-14-2008, 08:15 AM   #1
esad_b
We have a tent camper, and me and my buddies were planning on a little camping trip and wanted to mix it up a bit and take our camping trailer with us instead of just tents. Now my question is would the TJ be able to pull this? Thats what the trailer looks kind of like, i know the TJs towing capacity is not a lot but im quite unsure.
I remember last time i looked at our trailer i think it was rated at 800-900kg empty i believe.. Im gonna have to double check.
But we were planning on pulling it with my buddies 98 TJ, 4 cyl, 5 speed
Are we looking at problems or what? And it would only be 2 people in the jeep. and some gear
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
--- 2.5L | 5SPD | 31" Goodyear Authority A/T | 15" Alloy Ecco Wheels | Rubicon Rocker Guards ---
My Progress Page
esad_b is offline   Reply With Quote
Unread 07-14-2008, 08:47 AM   #2
alvinl
Itll pull it, just take it slow and stay alert. Stopping will be your biggest problem.
"Only two things are infinite, the universe and human stupidity; and I'm not sure about the former." - Albert Einstein
http://www.venemousduckracing.com
alvinl is offline   Reply With Quote
Unread 07-14-2008, 08:50 AM   #3
shunt
What does it weigh...? With a 4cyl it might be a lot of fun if you are going through hilly terrain....
One step beyond................
shunt is offline   Reply With Quote
Unread 07-14-2008, 08:55 AM   #4
esad_b
i believe last time i checked, cant remember exactly but i think it was in the 800-900kg range. but im going to double check on the weight exactly when i get home tonight. Hilly.. well perhaps just a bit too much
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 07-14-2008, 09:43 AM   #5
SOLOLUCKY
Puliing would prolly be ok. Its stopping that rates most vehicles. Does the trailer have electric brakes? If so, is your vehicle equipped with the elec. brake controller? Otherwise all the braking is on your Jeep brakes and that could be kinda bad in a panic situation. I cannot tell if it has surge brakes or not from the pic.
Obviously yer not gonna break any speed records going up hills but no jeep is.
Again brakes would be my main concern.
SOLOLUCKY is offline   Reply With Quote
Unread 07-14-2008, 10:17 AM   #6
esad_b
No electric brakes on the trailer.. so stopping is up to the jeep
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 07-14-2008, 10:20 AM   #7
jimkonow
oh, youll be fine. just keep it in the powerband.
2008 JK X, Silver
Winterforces ain't half bad in the mud!
The Silver Bullet
Originally Posted by Xerxes View Post
I need $$$$$$$ for O|||||||O
Originally Posted by BlueFlame View Post
But the REAL answer is a True Jeeper goes topless all winter with nothing more than a jacket and never complains. If he's cold, he never shows it, if he's wet and miserable he mans up and shuts up.
If you can't do that, put the top back on because you're a poser anyway.
jimkonow is offline   Reply With Quote
Unread 07-14-2008, 11:26 AM   #8
sknowskier
Getting up to speed is going to be brutal. Your clutch is definitly not going to like it either. But try it and see what happens. Be sure and let us know how it went when you get back. I've been wanting to do the same thing but I haven't had enough nerve to try. Don't forget to plan ahead for any stopping.
sknowskier is offline   Reply With Quote
Unread 07-14-2008, 11:30 AM   #9
esad_b
Yah well right now this trip is planned at near end of august LOL, but we just want to start planning ahead and stuff so its far away. But were kind of worried ourselves with the trailer or should we just throw some tents in and go
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 07-14-2008, 11:38 AM   #10
coachchuck
800-900kg empty translates to 1760-1980 lbs
Found several places online around your year (both before and after) it is 2000lbs (909kg) if trailer has brakes and 1000 lbs (455kg) if the trailer doesn't have brakes. The engine is not the factor ( you will go slower, but it will get it done). It is the brakes and wheel base of the TJ that is the limiting factor.
I pull a trailer that is about 800lbs (364kg) loaded with my YJ and you can really tell it on a quick stop. Your stopping distance is not real good.
Chuck
Sold : 93 YJ, 33s, 4.1, HO 4.0, AX15, d300 flipped
Building 90YJ. 37s, 5.38, 350, 4L60, np241, d44-ARB, D60-spool
coachchuck is offline   Reply With Quote
Unread 07-14-2008, 11:42 AM   #11
esad_b
Found several places online around your year (both before and after) it is 2000lbs (909kg) if trailer has brakes and 1000 lbs (455kg) if the trailer doesn't have brakes. The engine is not the factor. It is the brakes and wheel base of the TJ that is the limiting factor.
What you serious? So technically this trailer is over kill for the braking on the jeep?
What the hell you gonna pull with 455kg... That sucks!
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 07-14-2008, 11:59 AM   #12
waynehartwig
www.jeeperman.com
waynehartwig's Avatar
I pull a camp trailer with mine all the time. When I had stock TJ axles/brakes and 35's, it was harder to stop. Now I have 1 ton axles/brakes and it stops on a dime.
This is my setup....
...I have to use two drop hitches to get the tongue level
'04 Rubicon with all the goodies....
www.Jeeperman.com
www.DiffsOnly.com
waynehartwig is offline   Reply With Quote
Unread 07-14-2008, 01:18 PM   #13
sknowskier
I'm seeing a lot of 4.0 guys saying no problem but, what about with a little 4-banger? Mine seems to have trouble just getting itself up to speed on the highway...will it be able to do it pulling a trailer? I would love to pull one up to Colorado.
Unread 07-14-2008, 01:29 PM   #14
waynehartwig
www.jeeperman.com
That's true... I more less put in my $.02 because people were talking about stopping being the hard part.
www.Jeeperman.com
www.DiffsOnly.com
Unread 07-14-2008, 03:56 PM   #15
esad_b
Well i checked it out and the GAWR is : 805kg/1800lbs
So what are the verdicts?
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
