Quantcast Build a fuel efficient jeep - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Build a fuel efficient jeep
Old 06-04-2008, 07:51 PM   #1
vic777
Let's say you were building the most fuel efficient jeep you could for a DD from jeep and aftermarket parts ... can be CJ or Wrangler .... any engine, transmission, tires etc. how would you make it?
vic777 is offline   Reply With Quote
Old 06-04-2008, 08:32 PM   #2
yesterdaylight
i'd run a 4cyl YJ with 28's or smaller. I don't think there is anything more efficient jeepwise... unless you dropped a smaller engine in.
Green Jeep Club Member #172
Low Output 4 Cylinder Jeep Club Member # 23
Green 1995 4 Banger
If only my pocket was as green as my Jeep :D
yesterdaylight is offline   Reply With Quote
Old 06-04-2008, 08:32 PM   #3
YJ_95
its impossible. it would be a jeep tub on a honda civic everything else. the words jeep and fuel efficient dont go together
YJ_95 is offline   Reply With Quote
Old 06-04-2008, 08:36 PM   #4
Luckyduck
I wouldn't...
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/
Luckyduck is offline   Reply With Quote
Old 06-04-2008, 08:42 PM   #5
Brandon_YJ
1987 YJ Wrangler
OK, I'll bite.
If money wasn't much of a concern and using available parts:
Start with stock YJ, fiberglass body, do a coil conversion to save a few pounds and to make it easier to lower the Jeep, I'm thinking maybe 12" from ground to rockers.
Drivetrain would be a 2.2 Ecotec turbo mated to a 6sp tranny, no t-case (RWD only). A comparible diesle could be used as well.
High gearing (3.07?) and smaller tires (27"-28" in 15" aluminum rims).
Of course, who in the hell would want to drive it?
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote
Old 06-04-2008, 08:52 PM   #6
Mean Max
Mean Max's Avatar
Agreed, it's an oxymoron, kind of like Military Intelligence.
Don't bash me, I'm a former Marine, and I'm kidding.....
Mean Max is offline   Reply With Quote
Old 06-04-2008, 09:18 PM   #7
Ryanpowell167
buy a honda civic and a jeep decal.....
DARK STONE 2005 6.0l v-8 PowerStroke F-350
BLACK 1992 YJ 383Stroker, TH350, looking for a np205, d44 front, 12bolt rear, SOA on 4" springs, 35" Baja Claws, m8000, Electric fan, sliders, bumpers, crossmembers, all made by myself.
Black Jeep Club Member #167
Ryanpowell167 is offline   Reply With Quote
Old 06-04-2008, 09:31 PM   #8
1CleanTJ
of course a jeep isnt going to be a incredible mpg vehicle but if I had no limit money wise and were to build a more fuel efficient, yet still very capable jeep i'd start off with a stock base model TJ.
strip everything out of it leaving just the axle's/frame/body and the interior
reangle the windshield so its more \ then straight up.
highline the front and rear fenders to keep the COG low and add some narrow 33's on lightweight aluminum rims
put a small diesel engine mated to a 6 speed manual gearbox and atlas t-case.
run the diesel on bio-diesel
build a flat skid that goes front to rear of the jeep for better aerodynamic flow.
1CleanTJ is offline   Reply With Quote
Old 06-05-2008, 07:45 AM   #9
wendell
1987 YJ Wrangler
I would swap to synthetic fluids through out the drivetrain.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline   Reply With Quote
Old 06-05-2008, 08:42 AM   #10
bradyman1
Convert it to run off of electric power.
bradyman1 is offline   Reply With Quote
Old 06-05-2008, 09:47 AM   #11
h2oskikrazy
I think it might be possible for a Jeep to be somewhat fuel efficient and still retain some functionality. I would start with a TJ with the 2.4L engine and the 6 speed manual since that engine appears to be more fuel efficient than the 2.5L. You would want the SE version with the soft top and no A/C to keep the weight down. You would want to run the stock size 205/75/15 tire from the old SE with highway tread on lightweight wheels. (You could always buy a set of 31s on other wheels to swap on for off roading or snow). You would want to add nothing in terms of weight. Might want to have some tow hooks to put on if you go off roading. Then do everything you can to improve the resistance levels-change to synthetic diff, trans and transfer case fluids and synthetic oil in the engine. Clean new air filter, new spark plugs and wires. If you wanted to go further you could disconnect and remove the front drive shaft. But, that would cause another inconvenience if you wanted to go off roading.
With the above set up you should be able to get in the 20s fairly easily. Drive a steady 45 mph and you might pull high 20s.
h2oskikrazy is offline   Reply With Quote
Old 11-23-2009, 04:48 PM   #12
LKrux
OR lets say..
since fuel in typical cars is introduced to combustion as a liquid, which causes the engine to only use "some" of this liquid gasoline for combustion, as the rest of the unused fuel goes out through the exhaust and just becomes wasted money.
we could infact, turn this liquid into a vapor. Turning gasoline into a vapor would make it more explosive when introduced to the spark plug and in turn make more POWER & SAVE FUEL because one drop of liquid gasoline can create about 5X the power if converted into vapor.
id do that. come up with a system that turns gas into vapor and probably get about 40 mpg. and surprisingly..way more hp and torque. and it still looks like a jeep and functions like one.
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline   Reply With Quote
Old 11-23-2009, 04:59 PM   #13
diablo_331
Originally Posted by LKrux View Post
OR lets say..
Ive never heard of this and have no knowledge on the subject but if this were possible,Why hasnt it been dont yet?
'01 TJ, Waggy 44 front, D44 rear, Both locked and loaded, Savvy Armor, SuperWinch LP8500, MetalCloak bumper, and a heavy foot.
diablo_331 is offline   Reply With Quote
Old 11-23-2009, 07:02 PM   #14
2006_Sport
uhhhhhhhhhhhhhh yeahhh, because that makes it more fuel efficient.
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is offline   Reply With Quote
Old 11-23-2009, 07:18 PM   #15
corndogduff
Because its always cheaper to use the older, more inferior technology...
Fuel vaporisation is a real concept, and the reason why alot of people run mustang fuel injectors in their 4.0 engines. The mustang fuel injectors turn the liquid into a finer mist than the OEM injectors.
Duff.
[COLOR="Silver"]98 ZJ 5.9[/COLOR]
[COLOR="Green"]96 ZJ Laredo[/COLOR]
[URL="http://www.jeepforum.com/forum/groups/utah-jeepcrew/"]UT Jeepcrew #13[/URL]
[QUOTE=southerngirl]McDuff ftw[/QUOTE]
[SIZE="5"][URL="www.nightcrew.org"]NIGHTCREW[/URL][/SIZE]
corndogduff is offline   Reply With Quote
Glock Forum
