Break In Oil - JeepForum.com
post #1 of 11 Old 07-20-2013, 05:54 PM Thread Starter
jeepman6655
Break In Oil
My brother has a new Patriot and was told that they do use a break in oil! I thought this was something that was done away with years ago. Has anyone else ever heard of this??
jeepman6655 is offline
post #2 of 11 Old 07-20-2013, 09:17 PM
JBTJ
No need to, as it's already done at the factory. I would however change the oil at 1.5k.
JBTJ is offline
post #3 of 11 Old 07-22-2013, 08:45 PM
JohnRodriguez
the break in oils that are made today are intended for the older engines with flat tappet camshafts. the zinc forms a shock buffer coating on the lobes. it is also very good at ruining cats and emmision systems of a modern car.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #4 of 11 Old 07-25-2013, 02:12 PM
JeepDrew14
Just wanted to inquire about something as well, seeing as how JBTJ said to change at 1500 ... is that necessary?, i talked to my service tech at my dealer that i bought my 2013 Jk from and he said first oil change should be normal, around 5000km's. Just checking out of curiousity, as I'm just over 2000 km's. (not miles)
JeepDrew14 is offline
post #5 of 11 Old 07-25-2013, 02:56 PM
ops5
ops5's Avatar
That's only a problem if you are burning oil
ops5 is offline
post #6 of 11 Old 07-25-2013, 03:03 PM
ncb
I read an article that Blackstone Laboratory tested oils and found that only Honda uses a break-in additive (molybdenum-disulfide) from the factory. The lab said to follow what the owners manual states for changes for the first change. It definitely can't hurt to change it early. I think the focus should be put more into actually breaking in the engine as stated in the owners manual. I'm sure very few people leaving the dealership even know about breaking in a new engine. My WRX is the only car it was mentioned to carefully break-in. Some will argue the oil should be changed to remove any metal particles, but the filter will catch the small amount avoiding any internal engine damage. It's an opinion thing so one should do what makes them feel good.
ncb is offline
post #7 of 11 Old 07-25-2013, 04:08 PM
jay-h
Don't try to second guess the manufacturer. A lot of expertise goes into their oil advice.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #8 of 11 Old 07-25-2013, 09:12 PM
frenchy206
Just as a lot of expertise went into using the Dana 35. Ya. I'm pretty sure the manufacturers expertise goes into looking at the bottom line.
03 TJ Rubicon
frenchy206 is online now
post #9 of 11 Old 07-26-2013, 04:52 AM
jay-h
That may be true, but since the customer is paying for the oil, and any failure costs them in warranty repairs, I doubt 'cheaping out' is a factor here.
BTW if you read some of the tech papers by engineers at the manufacturers, or the American Petroleum Institute, you get a feel for how much expertise and testing is involved.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #10 of 11 Old 07-26-2013, 12:29 PM
AlbertaJeeper
I did my first change at about 8000 km (almost all highway so the light hadn't even come on yet). I really don't think its necessary to do a quick first oil change. If that was a harder stretch on the oil I would have changed to around 5 like you said
AlbertaJeeper is offline
post #11 of 11 Old 07-26-2013, 02:08 PM
JeepDrew14
thanks for the reply !
I don't do much highway mileage anyways so it'll go in for a 5k tune up.
thanks again
