Brake Fluid leaking around gas tank under the jeep - JeepForum.com
post #1 of 4 Old 05-22-2013, 01:26 PM Thread Starter
brennard
2000 YJ Wrangler
Okay, So the Brake light cam on the other day and my pedal was going all the way down. When I stopped and looked under the back end of my jeep I noticed Fluid leaking from the gas tank. I checked and it was not gas it was almost like oil. I checked the brake fluid and it was low. I had a friend press the brake pedal down while it was in park and you can hear a hissing noise and the leak became worse. I have read other post and am not sure if it is the wheel cylinder or the brake line. Any info would be great.
brennard is offline
post #2 of 4 Old 05-22-2013, 01:30 PM
bobjp
It's probably the brake line. It has broken and is spraying onto the gas tank.
97 TJ sport.
bobjp is offline
post #3 of 4 Old 05-22-2013, 03:59 PM
Jeepin72
My guess is that the brake line is the problem. And I would hazard a guess that it is roughly where the hard line and the soft line going to the rear axle join. It is allowing the fluid to shoot toward the tank and drain into the OEM tank compartment or "skid" if you will.
I am no brake expert, but isn't the wheel cylinder inside the drum? Not where you have discovered fluid.
Jeepin72 is offline
post #4 of 4 Old 05-23-2013, 11:31 AM
Bigshankhank
Yes, cylinder is inside the drum. Unless the oil is coming from behind the brake plate, then the leak is somewhere in the line.
Bigshankhank is offline
