BOUGHT A mOAB - HOW DO YOU USE THE AUTO SHIFTER - JeepForum.com
post #1 of 5 Old 05-29-2013, 06:06 AM Thread Starter
DARTICUS
When shifting the auto trans manually how does it work? Can you shift to a higher gear 5 while going slow? Do you have to be doing a certain speed? Seems like while going 25 mph I can't put in 5 only up to 4. Thanks Ron
DARTICUS is offline
post #2 of 5 Old 05-29-2013, 06:09 AM
cyberpyrot
just slap the stick to the right and it will shift throught the gears manualy.. I wish there was an option to turn it off as it often gets stuck in first when my wife puts her purse there. personaly I do not find it all that usefull. might be usefull when crawling.
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #3 of 5 Old 05-29-2013, 10:06 AM
222Doc
222Doc's Avatar
Yes it is, more like amazing. In a Rubi it really shows off its wizardry in the rocks. If you read up on what is in a w580, how it works. hard to belive we got this in a Jeep. you may not feel it but each gears has two stages.
But yes i too wish they had a OFF switch. as I have had people push it with an arm etc. Dumping us into low and reving the motor. It is touch little beast mine takes hardly a touch to shift it. just rest your hand and hit a bump can.
222Doc is online now
post #4 of 5 Old 05-29-2013, 07:16 PM
Airborne Lee
Airborne Lee's Avatar
I thought this was an issue also, but hitting neutral then back to drive is not an issue.
please buy this NEW IN BOX:
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline
post #5 of 5 Old 05-29-2013, 07:25 PM
222Doc
222Doc's Avatar
The use of to neutral is critical off road. Its a good thing they did make justa tap UP. If you ever get on something very steep where you are about to do a front over rear flop. N is like a cutch it will roll out. Just dont hit the brake until you KNOW it wont unload the springs and flip you over anyway. Like I said this trans they used is the cats a$$ compared to the last 42rle 4 speed. Pluss it can handle up to 426ftlbs. compared to the later trans that was about 250ftlbs. I think the best of the lastest Jeep is this trans not the motor. Put this trans in a 011 would be like going from 3:2o gears to 4:1. fun stuff just to bad its lke a 1200$ option.
