Bought a 93 Sahara tonight. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Bought a 93 Sahara tonight.
4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededBead Lock Wheels! Raceline, Trail Ready, & Trail-GearJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 09-27-2009, 06:40 PM   #16
Louie4
Injanir
Louie4's Avatar
Did you copy the image tag off photobucket? I have a '93 Sahara edition, just like yours but mine is hunter green. I've had a lot of fun with mine and still am. Nice looking jeep.
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Unread 09-27-2009, 07:32 PM   #17
plac
2013 Dodge Charger SRT8 Superbee
plac is offline   Reply With Quote
Unread 09-27-2009, 07:36 PM   #18
tennesseewj
Good looking Jeep.
I've been eying a '95 Sahara with 84k on that's at a dealership close to me lately They want 9 grand for it though They'd have to come way down for me to buy it, especially seeing yours for only $5
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline   Reply With Quote
Unread 09-27-2009, 07:40 PM   #19
plac
ya although KBB private party for my jeep in "good" condition was $5200.. This Jeep would barely qualify as good, and no one pays actual KBB prices these days. so at first I thought I didnt get a good deal. But then I think about 70k original plus brand new clutch and tires. Then the deal makes sense. (also a new windsheild 2 months ago).. no leaks that I can see. engine shakes a tiny bit at idle when stopped, but im used to brand new cars that are butter smooth. the tach is steady so i guess its ok. It just had a tune up a year ago too, so the plugs and cap/rotor are probably fine. Its been hot here, like 90F.. I floored it in 5th once and heard some pinging. I might check my timing.. i filled up today, this is an 18 gallon tank!! Cost me $55!! I used mid grade instead of cheapest just because of that pinging issue I had..
Unread 09-27-2009, 07:42 PM   #20
asf06
93 sahara FTW
1993 YJ, too broke to swap the tranny and my 60s
email me at franzas@comcast.net
Originally Posted by Rob99 View Post
It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
PIKE Jeepers #1
Jeep Smokeless #4
asf06 is offline   Reply With Quote
Unread 09-27-2009, 07:48 PM   #21
Hesher420
Hesher420's Avatar
Originally Posted by plac View Post
dddddddddddd
**'06 Blacked Out LJ**
> > > LJ Owners Group < < <
Black Jeep Society
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline   Reply With Quote
Unread 09-27-2009, 07:51 PM   #22
Hesher420
Hesher420's Avatar
Example:
What u had
[img] [URL="http://74.220.202.31/%7Ebellbott/images/newjeep31.jpg"]http://74.220.202.31/~bellbott/images/newjeep31.jpg[/URL][/img]
What it should be
[IMG]http://74.220.202.31/%7Ebellbott/images/newjeep31.jpg[/IMG]
remove the URL tags and the space before it
Black Jeep Society
Unread 09-27-2009, 08:02 PM   #23
asf06
holy **** that is clean. good find
PIKE Jeepers #1
Jeep Smokeless #4
Unread 09-27-2009, 08:22 PM   #24
plac
is it clean for a jeep? i thought its pretty good for 1993.
more work done, i cant keep my hands off it.
-i went to check the timing.. there are no specs on the hood sticker.. it says its non user adjustable.
-checked tire pressures, one was 26 and rest were 30. i like a firm tire so i raised them all to an even 36psi.
-found a brand new radiator and water pump still shiney. i was worried about water hoses getting old and popping but they dont feel crispy yet..
-no leaks EXCEPT for some transfer case seal issues.. entire engine compartment is dry top to bottom.
-checked oil, just at bottom of safe mark, so I might add a quart. 10W-30 for these things in Cali? I'll add a cheap one until I go full synthetic.
-my oil pressure is up around a solid 60psi most of the time, seems pretty strong.
-found a spark plug wedged behind my coil, removed it..
i want some more modern rims. i like modern oem rims. do i have steelies? i can't even tell. I know I have 5 lug nuts on each wheel. anyone know my bolt pattern so i can look up some new rims?
tomorrow i gotta smog it. i hope it passes.. then i can register it in my name.
Unread 09-27-2009, 08:25 PM   #25
plac
Originally Posted by Mudvain View Post
i scored mine in socal about 2 months ago, it had been there since '92. very clean and rust free.
-your a/c may need a good charge. does the blower work with your heat settings?
-the wipers are sitting correct, tis the righteousness of owning a YJ
-are your doors needing a 'lift' when closing or maybe just some PB blaster to loosen the mechanisms up a bit?
i'm sure more will chime in. nice YJ
thanks, so i have a YJ? cool. My doors dont need a lift at all. Its just the pressure it takes to slam the door latch over that sticker. The latch is very stiff it seems.
i guess no one will really know if i can just remove that Clifford alarm thing and trace all the wires. I guess I'll have to try. I saw some sort of module under my steering wheel. I'll have to trace all the wires.
Unread 09-27-2009, 08:28 PM   #26
asf06
ya my latches are stiff, too. slam it harder.
it is real nice for a 93. mine also had 70k miles on it. yes, it takes 10W-30
PIKE Jeepers #1
Jeep Smokeless #4
Unread 09-27-2009, 08:32 PM   #27
Zembonez
That appears to be a pretty solid snag! Congrats.
Zembonez - XJ ADDICT - 2000 XJ (my new project) - 2007 GMC Sierra - 09 Scion xB - TruckModCentral - My Truck Forum
Originally Posted by Cowboy Cadillac
Canada has 4 seasons...Almost winter, winter, still winter and road construction
Zembonez is offline   Reply With Quote
Unread 09-27-2009, 09:04 PM   #28
plac
I'll be driving it a lot until i realize how bad the gas mileage is. then i'll prob go back to my 2009 GTI and save this for weekends around town.
Unread 09-27-2009, 10:45 PM   #29
grnjp88
'93 Sahara is the way to go!!
Nice find.
1993 Jeep Wrangler Sahara °lllll°
1969 VW Beetle Sedan (O\U|U/O)
grnjp88 is offline   Reply With Quote
Unread 09-27-2009, 11:53 PM   #30
armyRN
armyRN's Avatar
Your YJ has a 5 on 4.5" wheel bolt pattern. The YJ and the TJ have the same bolt pattern. Earlier Jeeps (CJ's) have a 5 on 5.5" bolt pattern. You'll have tons of options for wheels, both factory and aftermarket.
Nice find.
armyRN is offline   Reply With Quote
