Bikini Top w/ Drill-in Header Bar - JeepForum.com
post #1 of 5 Old 08-09-2012, 01:32 PM Thread Starter
funky_boss23
Hello all.
Just curious to know if anyone else has this problem.
I have a Mopar bikini top with drill-in header bar.
Right where the hard top would normally clamp in, I get serious leaking if it has been raining. I do my part to bang all the water off the roof prior to taking her out but you know you can't get it all.
If I stop, water leaks right through where the hard top would clamp in. It just so happens that it land on the steering column.
Because of this, I am on my second clockspring.
So, do you have this issue as well? Were you able to remedy is with a fix and how so?
Thanks in advance for the assistance.
JT
funky_boss23 is offline
post #2 of 5 Old 08-10-2012, 04:03 PM Thread Starter
funky_boss23
31 views.
Has no one had this problem before?
post #3 of 5 Old 08-10-2012, 08:17 PM
Eric1371
Can't speak for the mopar drill in header but I used my best top drill in header twice in the last 9 months I've owned it, either hard top or no top for this guy...
Semper fidelis.
Eric1371 is offline
post #4 of 5 Old 08-10-2012, 08:22 PM
relgnarw
I've not had that problem. I used to have that setup before but I switched to a no drill style and it works fine. Why not just get rid of the drill/screw type and go to the no drill type? I know you have the one setup but it seems to me if you were having troubles with it it might be easier to just get rid of it. It might save alot of aggravation in the long run.
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
relgnarw is offline
post #5 of 5 Old 08-10-2012, 08:35 PM
uncleroman
i had that setup. it looked like it could leak but never tested it now i have a rampage that i leave safari 99.9% no leaks
uncleroman is offline
Drill-In Header for Bikini Top spsmith TJ Wrangler Technical Forum 4 03-15-2011 09:26 PM
Bestop Bikini w/no-drill header gap alecmcmahon Wrangler General Discussion 5 12-10-2009 04:20 PM
drill or no-drill bikini header Gjones TJ Wrangler Technical Forum 25 03-19-2007 09:34 PM
97 bikini top & no drill header on 03? Texas TJ TJ Wrangler Technical Forum 2 09-26-2005 10:34 PM
no drill header for bikini FL 4.0L TJ Wrangler Technical Forum 4 01-08-2005 05:43 PM
