Bestop Soft Door Fix - JeepForum.com
post #1 of 3 Old 06-11-2012, 08:49 AM Thread Starter
ScottHerman
2010 JK Wrangler
We enjoy taking trips with the doors off, and we got a set of Bestop soft doors for rain. At highway speeds, the top of the door separates from the body by about two inches. The first time a semi passed me, I thought the doors were coming off! After much trial and error, I found a cheap, easy and effective fix.
I got a grommet kit and installed grommets in the top front corner of each door top. I tied a 1/16" cord to the frame of each door and threaded them through the grommet. When we're going to be traveling at highway speeds, I simply tie the strings together. I used a figure-eight-on-a-bight to make a loop in one string and I use a modified trucker's hitch to join them, so that tension is maintained. This fixed the problem.
ScottHerman is offline
post #2 of 3 Old 06-11-2012, 09:19 AM
SteveBad
SteveBad's Avatar
2011 JK Wrangler
I understand the problem, and I think I understand your solution.
So you hve a cord going clear across the car, side to side ?
Can't you secure it with a small bungee to the sunvisor, or some such ,
and avoid the side-to-side cord?
" Leave the gun .... take the cannolis. "
SteveBad is offline
post #3 of 3 Old 06-11-2012, 10:18 AM Thread Starter
ScottHerman
2010 JK Wrangler
Sure. I considered that, but the more I looked at it the more I realized it would be easier to get the exact tension I wanted with a cord connecting the two. I use them so seldom that it didn't make sense to invest a lot of time and effort into a fix. The frame of the door is covered in such a way that attaching directly to it would have put tension on the fabric, which I wanted to avoid by using the grommets. Also, I like knots so that solution suited me personally. When I did it, I was actually planning on going with a bungee, but this worked so well I didn't see a reason.
bestop , soft doors
Bestop door surrounds with 07 soft top rob5059MOD JK Wrangler Technical Forum 2 03-25-2012 10:51 AM
Mopar (Bestop) 4 door JK Soft top Boot likefre JK Wrangler Technical Forum 21 08-02-2007 02:39 PM
Bestop soft door colors FlaJeepin TJ Wrangler Technical Forum 1 11-12-2006 11:53 AM
Bestop soft upper door sliders? MP Curtis TJ Wrangler Technical Forum 4 05-08-2006 04:55 PM
Bestop 2 piece soft door security??? natef26 TJ Wrangler Technical Forum 3 02-24-2005 04:31 PM
