Best Headlights - JeepForum.com
post #1 of 15 Old 12-01-2010, 07:22 PM Thread Starter
sivart9
Best Headlights
Im hoping there is an obvious answer and every one will say the same thing and not none of that "its a matter of opinion" crap.
Whats the absolute best headlights on the market for an 00 SE? I wanna be able to see as best as possible at night.
sivart9 is offline
post #2 of 15 Old 12-01-2010, 07:24 PM
ajf1994
http://www.jeepforum.com/forum/f9/h-...tj-wow-842999/
DDM 55watt 5000K Hi/Low H4 with Hella H4 E-Code housings.
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #3 of 15 Old 12-01-2010, 11:05 PM
baritone_mike
OSRAM SYLVANIA - SilverStar ULTRA
If all you want is to be able to see. They also only last like a 1/4th of a normal headlight. The only problem I could see is that people will probably flash thier lights at you because they are really bright. (I do not have them but they are the super bright ones)
baritone_mike is offline
post #4 of 15 Old 12-02-2010, 12:55 AM
Hondo
I've never driven a vehicle that has HID's so I cannot comment in that regard, but I do have the Hella E-code housings on my Jeep with just standard Sylvania bulbs and they are friggin' amazing. They are the best headlights I've personally seen on any vehicle. Ever.
Hondo is offline
post #5 of 15 Old 12-02-2010, 05:11 AM
paul84043
Be careful changing out your headlights and check your local laws. Some areas only allow certain color of lights to be used as "headlights" and some regions even loosely enforce a specific brand based on the original spec of your vehicle.
I didn't know it was an issue until I stumbled across an article recently, but google it and you'll see that it's becoming more of a problem, or more to the point, a source if income as cities are scrambling for money and will get it any way they can.
Just a thought.
paul84043 is offline
post #6 of 15 Old 12-02-2010, 07:38 AM
vanwyk4257
Hella E-codes are very good. I have hella H4's on my YJ with a relay wiring setup and stock bulbs and am very happy with the light output. I had a set of E-codes on my old Porsche 944 with relays and some very high wattage bulbs and they put out more light than the factory HID's on my current daily driver.
Whatever lights you run, invest in or fabricate a wiring harness with relays to put power to the lights. Voltage loss through the skimpy factory wiring harness has a significant effect on degrading light output. Use at least 12 gauge wire if you fabricate one, I did a test on a couple sets of Hella 500 lights once, wired one set with the stock 18ga. harness, and the other with 12ga. The lights powered with the 12ga. harness were significantly brighter.
2010 Jeep JK Wrangler Unlimited Sport - Red Rock
FOR SALE - Asking $26000 OBO.
vanwyk4257 is offline
post #7 of 15 Old 12-02-2010, 05:44 PM
jay-h
Hella's are great in my experience.
HIDs are good in theory, but the aftermarket ones are not street legal because they do not focus properly. Lots of light, but little control. Factory HIDs are great but there is no sensible way to retrofit them into an older vehicle.
LEDs hold promise but are probably not ready for prime time yet.
jay-h is offline
post #8 of 15 Old 12-02-2010, 06:09 PM
RogueSpear2023
The best possible light is going to come from a replacement housing, 6024 Bulbs are expensive and out dated. The replacement housing will allow you to run H4 bulbs. This is really up to preference and how much work you want for your self, you can run regular H4 bulbs if you want, upgrade your wiring so you can run brighter ones, or go all the way to HID. HID will probably be the best, but also costs quite a bit, and there is some work involved.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #9 of 15 Old 12-03-2010, 09:46 AM
roughknight69
ipf h4 housings and fat boy 2s
roughknight69 is offline
post #10 of 15 Old 12-03-2010, 10:27 AM
StvDiego
And there's the problem, there is no "best" anything for a Jeep. it's all about what's best for you and how and where you use your Jeep. It really is a matter of opinion
Look at the responses so far, all different opinions...
I have IPF's, Fatboys and a wiring harness that cost a bundle of money and are no better in light output/pattern/visibility that my roommates Jeep of the same year model with Deltas and Silverstars for less than half the cost.
I've driven rigs with all LED's, phenomenal light output but in the desert/rockcrawling wheeling I do they were more of a hindrance than a plus. A simple flood light and good rock lights work best there. But on semi hi-speed runs across the desert I want more long-range light.
So do you want more light for highway driving, city driving, off-road in rocks, mud, snow. mountains, plains, a combo light?? There's a lot more questions to ask other than "the best" before you can make an informed decision about which light is best for you personally.
Other than that, listen to other's opinions and experiences and then go out and buy what you think will work best for you.
Some good tech info on lighting in general, may give you some ideas: Daniel Stern Lighting
StvDiego is offline
post #11 of 15 Old 12-03-2010, 11:08 AM
jay-h
Always rewire (direct from the battery using relays) for high wattage bulbs. DO NOT use your existing wiring or headlight switch to carry the current. Also ground to the chassis, battery or engine block, do not ground through the harness.
jay-h is offline
post #12 of 15 Old 12-04-2010, 12:02 PM
roughknight69
i did lol just forgot to mention that part imma few drinks in
post #13 of 15 Old 12-04-2010, 01:49 PM
wendell
1987 YJ Wrangler
Hella is the best for the money spent in my experience.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #14 of 15 Old 12-06-2010, 10:12 AM
Loamy
I just put on the KC 7" DOT Approved H4 lights on my jeep. Some people will argue that the European spec beam pattern is better, but these were a great improvement. I appreciated the fact that the beam pattern was extended below the normal range so despite the lift, my headlights now actually illuminate the road surface. Also, lexan is an incredibly durable material for a lens. It may scratch a little easier than glass, but there is no way an impact will crack or break it.
'02 TJ, NV4500, 4.3 Atlas II, 35x12.50 Baja Claws
Loamy is offline
post #15 of 15 Old 12-06-2010, 01:04 PM
Jonny Jeep
Jonny Jeep's Avatar
This may help with lens choice. JP Magazine headlamp shootout...
Jeep Headlight Shootout | Jp Magazine Article at Automotive.com
Jonny Jeep is offline
Headlights Out?? HELP CONNOR_99TJ TJ Wrangler Technical Forum 4 06-05-2010 09:21 PM
has anyone used these for headlights? joeskyline06 TJ Wrangler Technical Forum 11 05-22-2010 11:24 AM
both headlights out rocklee YJ Wrangler Technical Forum 18 11-23-2008 09:16 PM
Headlights go on, radio goes off. Headlights off, radio back on gary1 YJ Wrangler Technical Forum 10 10-29-2008 09:07 PM
Headlights tennisjon2002 YJ Wrangler Technical Forum 6 03-19-2005 04:57 PM
